StarTech.com 15m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable
Quicklinx: FBZNWS00 Mfr#: A50FBLCLC15
This OM3 LC to LC Multimode Duplex Fiber Optic Patch cable features 50/125 micron fiber and supports high-bandwidth data transmission over a 10 Gigabit Ethernet connection.
With laser-optimized multimode fiber (LOMMF), the patch cable is ideal for connecting 850 nm Vertical Cavity Surface Emitting Laser (VCSEL) and LED sources. The high-speed connectivity on the aqua fiber-optic cable provides a high-bandwidth solution for your data centers or high-density applications.
Each OM3 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, this fiber-optic cable ensures minimal smoke, toxicity and corrosion when exposed to high sources of heat, or in the event of a fire. It's the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
StarTech.com 15m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable - Aqua - 50/125 - LSZH Fiber Optic Cable - 10Gb (A50FBLCLC15) - patch cable - 15 m - aqua
Patch cable - OM3
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, Laser-optimized multimode fibre (LOMMF)
Length
15 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Aqua
P/N: SV565FXHD4KU
Network Cable Type
Patch cable - OM3
Duplex fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
50 / 125 micron
Length
15 m
Aqua
Connector
RoHS
P/N: SV565FXHD4KU
FBZN StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £33.25
FBZN StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £19.33
FBZN StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £24.53
FBZN StarTech.com 7m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable In Stock £25.13
