StarTech.com 15m HDMI to DIV-D Cable – M/M
Quicklinx: 7Y38WS00 Mfr#: HDDVIMM15M
Length: 15m
£14.35 ex VAT
£17.22 inc VAT
Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDDVIMM15M 15-meter HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
StarTech.com 15m High Speed HDMI Cable to DVI Digital Video Monitor - adapter cable - HDMI / DVI - 15 m
Cable
Adapter cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
24
Length
15 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
Thumbscrews
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
Shielded
24
Jacket Material
PVC
Shielding Material
Length
15 m
Plated Connector
Gold
Thumbscrews
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
RoHS
Limited warranty - lifetime
7Y38 StarTech.com 10m HDMI to DVI-D Cable - M/M In Stock £32.49
7Y38 StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor In Stock £7.78
7Y38 StarTech.com 3m HDMI to DVI-D Cable - M/M In Stock £9.63
7Y38 StarTech.com 5m HDMI to DVI-D Cable – M/M In Stock £9.74
7Y38 StarTech.com 1m HDMI to DVI-D Cable - M/M In Stock £7.31
7Y38 StarTech.com 0.5m HDMI to DVI-D Cable - M/M In Stock £7.58
Length: 15m
