StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P0DWS00 Mfr#: MXTMMHQ15M
Length: 15m
£40.88 ex VAT
£49.05 inc VAT
Connect your VGA monitor with the highest quality connection available. This 15-meter high resolution VGA monitor cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech 15m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 15 m
VGA cable
Triple shielded twisted pair coaxial
Molded
Cable Length
15 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Molded
Cable Length
15 m
Connector
RoHS
7P0D StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.33
7P0D StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £40.88
7P0D StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £7.32
7P0D StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £10.25
Length: 15m
