StarTech.com 15m Active DisplayPort Cable
Quicklinx: HFNYWS00 Mfr#: DP14A-15M-DP-CABLE
Length: 15m
Hurry, only 3 left in stock!
£128.32 ex VAT
£153.98 inc VAT
Connect a 4K/8K DisplayPort 1.4-enabled monitor to a source or MST-enabled hub, using this VESA-Certified Active DisplayPort 1.4 Cable. The active signal booster ensures reliable audio and 8K video output at up to 50ft (15.2m) without a DisplayPort repeater and external power source. This active DP 1.4 cable is unidirectional with conveniently labeled connectors for source and display to simplify setup.
  • VESA-Certified DP8K
    For seamless performance and compatibility between DisplayPort-enabled devices, the Active DisplayPort Cable is VESA Certified, for guaranteed DP 1.4 support and backward compatibility with DP 1.3/1.2
  • Durable Design
    This long DisplayPort cable features a flexible TPE outer jacket to reduce wear from corner bends and long cable runs. Robust strain reliefs enable soft and flexible bends, for convenient positioning of the cable. The latching DP connectors are gold plated for improved conductivity and anti-tarnish properties, and attaches securely to the device to prevent accidental disconnection.
  • Supported DisplayPort 1.4 Features:
    This 8K DisplayPort cable supports all DP 1.4 features: • Resolutions up to 8K 60Hz, 4K 120Hz, 1440p 240Hz with a compatible DP source and display • HDCP 2.2 support • High Bit Rate 3 (HBR3) bandwidth of 32.4Gbps • High Dynamic Range 10 (HDR10) • Display Stream Compression 1.2 (DSC 1.2) • Multi-Stream Transport (MST) for daisy-chaining multiple monitors • 32 Uncompressed Digital Audio Channels • Backward compatible with 5K 60Hz, 4K 120Hz and previous DP versions The Active DP Cable is constructed with aluminum-mylar shielding to minimize EMI interference for clear and reliable audio/video output. This VESA-certified DP cable is designed for long-term reliability, and is the ideal solution for setting up boardrooms, video walls, and TV signage.
StarTech.com 50ft (15m) VESA-Certified Active DisplayPort 1.4 Cable, DP8K w/HBR3/HDR10/MST/DSC 1.2/HDCP 2.2, 8K 60Hz, 4K 120Hz Video - Active DP 1.4 Cable M/M (DP14A-15M-DP-CABLE) - DisplayPort cable - DisplayPort to DisplayPort - 15 m
DisplayPort cable
Active Copper Cable, active adapter, 4K support, 8K support, Multi-Stream Transport, 32 uncompressed digital audio channels, backwards compatible with USB1.1, 25.92 Gbps transfer rate, up to 32.4 Gbps bandwidth, strain relief, halogen free
Length
15 m
Connector
20 pin DisplayPort - male
Connector (Second End)
DisplayPort 1.4
DisplayPort cable
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
24/28
Plated Connector
Gold
Length
15 m
Outside Diameter
7.5 mm
Connector
DisplayPort 1.4, VW-1, HDCP 2.2, DSC 1.2, RoHS, WEEE
Shipping Width
46 cm
Shipping Depth
35 cm
Shipping Height
15 cm
Shipping Weight
1 kg
Length: 15m
