StarTech.com 15m Active DisplayPort Cable - DP to DP M/M
Quicklinx: 8Y6DWS00 Mfr#: DISPL15MA
Length: 15m
£87.40 ex VAT
£104.88 inc VAT
Connect DisplayPort-equipped devices up to 15m away with no signal loss. The DISPL15MA 15m Active DisplayPort Cable features a built-in active signal booster for a connection distance of up to 50 feet (15m) between your DisplayPort-enabled devices - more than double the DisplayPort connection distance limitation of 16ft, with no signal loss.
This durable yet lightweight active DP cable features a thinner 32 AWG wire construction that allows for a more flexible installation with minimal clutter. Plus, the cable features built-in amplifier circuitry which actively boosts the DisplayPort signal with no external power needed.
The 15m cable offers a bandwidth of 10.8 Gbps with support for maximum resolutions up to WQXGA (2560×1600) and optional audio support. The cable is both HDCP and DPCP capable, which ensures that digitally protected content is displayed properly.
This cable features unidirectional architecture which requires that the cable is installed in the correct direction. Please refer to the "source" and "display" labels on the DisplayPort connectors, in order to ensure that the display device (monitor, projector etc.) and the DisplayPort source are connected properly.
StarTech.com 50 ft DisplayPort Cable with Latches - Active - 2560 x 1600 - DPCP & HDCP - Male to Male DP Video Monitor Cable (DISPL15MA) - DisplayPort cable - 15 m
DisplayPort cable
Double shielded
Active cable (signal regeneration), latched, DPCP compliant
Length
15 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
DisplayPort cable
Double shielded
Shielding Material
American Wire Gauge (AWG)
32
Plated Connector
Nickel
Length
15 m
Connector
20 pin DisplayPort - male
RoHS
Length: 15m
