StarTech.com 15m (50 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 8MR8WS00 Mfr#: HDMM15MA
Type: HDMI
Length: 15m
£69.34 ex VAT
£83.20 inc VAT
The HDMM15MA 50 ft Active High Speed HDMI® Cable features a built-in active signal booster for a connection distance of up to 50 feet (15m) between your HDMI-enabled devices, with no signal loss.
This durable yet lightweight cable features thinner HDMI wire construction that allows for a more flexible installation with minimal clutter. Plus, the cable features built-in amplifier circuitry which actively boosts the HDMI signal with no external power required.
This 15 meter HDMI cable is backed by StarTech.com's 2-year Warranty.
Please Note: This cable features unidirectional architecture which requires that the cable is installed in the correct direction. Please refer to the "source" and "display" labels on the HDMI connectors in order to ensure that the device and the HDMI source are connected properly.
The StarTech.com Advantage
No HDMI signal loss, even at a distance of up to 50 feet (15 meters) Flexible construction for easier installations
Technical Specifications
  • Warranty 2 Years
  • Connector Plating Gold
  • Cable Jacket Type PVC - Polyvinyl Chloride
  • Cable Shield Type Aluminum-Mylar Foil with Braid
  • Fire Rating CMG Rated (General Purpose)
  • Connector A 1 - HDMI (19 pin) Male
  • Connector B 1 - HDMI (19 pin) Male
  • Cable Length 15 m [49.2 ft]
  • Color Black
  • Connector Style Straight
  • Product Length 15 m [49.2 ft]
  • Product Weight 1.1 kg [2.5 lb]
  • Wire Gauge 26 AWG
StarTech.com 15m (50 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M- 1080p A/V, Gold-Plated (HDMM15MA) - HDMI cable - 15 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
26
Length
15 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Active cable (signal regeneration)
Cable Type
HDMI cable
Double shielded
26
Jacket Material
PVC
Shielding Material
Length
15 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
8MR8 StarTech.com 15m (50 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £69.34
8MR8 StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £58.11
Type: HDMI
Length: 15m
Stock Status: In stock
