StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M
Quicklinx: 8T5DWS00 Mfr#: USB2HAB50AC
Length: 15m
Select:
19 in stock
£25.76 ex VAT
£30.91 inc VAT
Connect USB 2.0 devices up to 50ft away, with no signal loss. The USB2HAB50AC 50ft / 15m USB A to B cable incorporates bus-powered active circuitry, which enables it to perform beyond the 5-meter limit of a standard USB cable.
The longer connection provides enough cable length to connect your USB 2.0 peripherals up to 15m away from your PC, Laptop or Server, allowing you to position your devices as needed.
This active USB 2.0 cable is designed with top quality materials for high durability.
StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M - USB cable - 15 m
USB cable
Double shielded
Active cable (signal regeneration)
Length
15 m
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
USB cable
Double shielded
American Wire Gauge (AWG)
24
Plated Connector
Nickel
Length
15 m
Connector
USB / USB 2.0, FCC, RoHS
8T5D StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
8T5D StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.81
8T5D StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.17
8T5D StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £16.43
8T5D StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M In Stock £29.16
8T5D StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M In Stock £25.76
Length: 15m
Price Range Ex VAT: 0 - 50
