Connect USB 2.0 devices up to 50ft away, with no signal loss. The USB2HAB50AC 50ft / 15m USB A to B cable incorporates bus-powered active circuitry, which enables it to perform beyond the 5-meter limit of a standard USB cable.
The longer connection provides enough cable length to connect your USB 2.0 peripherals up to 15m away from your PC, Laptop or Server, allowing you to position your devices as needed.
This active USB 2.0 cable is designed with top quality materials for high durability.
- StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - Long 15 m USB Cable - 50 ft USB Printer Cable - 1x USB A (M), 1x USB B (M) - Black (USB2HAB50AC) - USB cable - USB Type B to USB - 15 m
- USB cable
- Technology
- Double shielded
- Active cable (signal regeneration)
- Length
- 15 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: ICUSB232D
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Nickel
- Length
- 15 m
- Black
- Connector
- USB / USB 2.0, FCC, RoHS
- 2-year warranty
- Designed For
- P/N: ICUSB232D
