StarTech.com 15m / 49.2ft Active Optical DisplayPort 1.4 Cable - 8K 60Hz
Quicklinx: FLXQWS00 Mfr#: DP14MM15MAO
This active optical DisplayPort 1.4 cable lets you connect your DP laptop or desktop computer to an ultra-high definition 8K monitor, TV or projector. The built-in active signal booster ensures a reliable connection at a distance up to 15 m (49.2 ft.) between your DisplayPort enabled devices.
This 8K DisplayPort cable supports all DP 1.4 features: Resolutions up to 8K at 60Hz; HDCP 2.2 support; High Bit Rate 3 (HBR3) bandwidth of 32.4Gbps; High Dynamic Range (HDR); Multi-Stream Transport (MST) for daisy-chaining multiple monitors; 32 uncompressed digital audio channels; Backward compatible with 5K 60Hz, 4K 120Hz and previous generations of DP.
This durable yet lightweight active DP 1.4 cable features both copper and optical fiber conductors enabling a more flexible installation with minimal clutter. Plus, the cable features built-in amplifier circuitry which actively boosts the DisplayPort signal with no external power needed. The DisplayPort connectors also feature latches that provide a secure connection between your devices.
Comprised of a fiber and copper wire mix, this active cable is less susceptible to EMI interference, for a clear and reliable audio/video signal.
Note: This cable features unidirectional architecture, please refer to the "display" label on the HDMI connectors to ensure installed in the correct direction.
  • High-quality connectivity
    The 15m /49.2ft Active Optical DisplayPort 1.4 Cable is designed with a 28 American Wire Gauge (AWG) and nickel-plated connectors, ensuring stable and high-quality video transmission. Its EMI protection reduces interference, while HDR support and High Bit Rate 3 (HBR3) enable a vivid and dynamic viewing experience.
  • Advanced display technology
    With support for DisplayPort Multi-Stream Transport (MST) and compliance with DisplayPort 1.4 standards, this cable facilitates multi-monitor setups and high-resolution displays up to 8K at 60Hz. The active optical cable (AOC) technology provides superior signal quality over long distances without signal degradation.
  • Durable and secure design
    Featuring a durable PVC jacket and aluminum mylar foil with braid shielding, the cable is built to last and withstand rigorous use. The latched connector design ensures a secure and stable connection to prevent accidental disconnections.
StarTech 15m /49.2ft Active Optical DisplayPort 1.4 Cable - 8K 60Hz - DisplayPort cable - DisplayPort to DisplayPort - 15 m
DisplayPort cable
8K support, Active Optical Cable (AOC), EMI protection, HDR support, DisplayPort Multi-Stream Transport (MST), High Bit Rate 3 (HBR3)
Cable Length
15 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 1.4
DisplayPort cable
Shielding Material
Jacket Material
PVC
28
Plated Connector
Nickel
Cable Length
15 m
422 g
Connector
DisplayPort 1.4, RoHS, REACH, HDCP 2.2
Shipping Width
26.5 cm
Shipping Depth
26.5 cm
Shipping Height
7.8 cm
Shipping Weight
700 g
