StarTech.com 15in Laptop Privacy Screen - Magnetic - 16:10 Aspect Ratio
Quicklinx: FNLCWS00 Mfr#: PRIVSCNMAC15
Device Type: Macbook
Type: Privacy Screen
Device Screen Size: 15
Colour: Transparent
£54.41 ex VAT
£65.29 inc VAT
Laptop Privacy Filter Blue Light Reduction Matte or Glossy 2-Year Warranty. The laptop privacy screen is easy to attach and remove. Simply attach the MacBook privacy filter to your laptop with using the magnetic strips. This magnetic privacy screen is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Protect Your Privacy
The laptop privacy filter is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. Whether travelling, working in the office or sitting in a busy coffee shop, you can have a peace of mind because you know your screen is protected with the 30+/- degree privacy viewing angle.
The display privacy filter is designed to filter blue light (390nm~480 wavelength) that can cause eye strain and can disrupt sleeping patterns.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
This PRIVSCNMAC15 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Easy Magnetic Installation
    The laptop privacy screen is easy to attach and remove. Simply attach the MacBook privacy filter to your laptop using the built-in magnetic strip at the top of the privacy screen This magnetic privacy screen is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity. In order to close and put your laptop to sleep the privacy screen must be removed. A protective folder is included so you can protect the privacy screen from damage when not in use. The privacy screen is also extremely easy to clean when removed from your laptop.
  • Protect Your Privacy
    The laptop privacy filter is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. Whether travelling, working in the office or sitting in a busy coffee shop, you can have a peace of mind because you know your screen is protected with the 30+/- degree privacy viewing angle. The privacy screen is also designed with a convenient cutout for the webcam of the MacBook Pro 15" (2016-2018).
  • Blue Light Reduction
    Lowering blue light exposure is important. To reduce digital eye strain, the monitor privacy film blocks between 40% to 51% of the blue light in the wavelength range of 380nm to 480nm.
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The TAA compliant PRIVSCNMAC15 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Laptop Privacy Screen for 15 inch MacBook Pro & MacBook Air, Magnetic Removable Security Filter, Blue Light Reducing Screen Protector 16:10, Matte/Glossy, +/-30 Degree Viewing - Blue Light Filter - notebook privacy filter
Notebook privacy filter
Installation Type
Removable - magnetic
Package Content
Wiping cloth, L folder
Transparent
Product Material
Plastic
34.2 cm 22.2 cm
48 g
Display Screen Size Compatibility
15"
Anti-glare, reversible, +/- 30° visible angle, 25% blue light reduction
P/N: LTSTND2IN1
Product Material
Plastic
Package Content
34.2 cm
22.2 cm
48 g
25.8 cm x 0.3 cm x 38.4 cm / 208 g
15"
Transparent
Display Filter
Installation Type
Aspect Ratio
16:10
Scratch Resistant
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
P/N: LTSTND2IN1
FNLC StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £31.60
FNLC StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio In Stock £32.64
FNLC StarTech.com Laptop Stand for Desk In Stock £63.96
FNLC StarTech.com 13.3in Laptop Privacy Screen In Stock £28.33
FNLC StarTech.com 14in Laptop Privacy Screen In Stock £29.56
FNLC StarTech.com 14in MacBook Privacy Screen In Stock £30.99
FNLC StarTech.com 16in MacBook Privacy Screen In Stock £31.12
FNLC StarTech.com 13.5in Laptop Privacy Screen In Stock £29.12
FNLC StarTech.com 15.6" Laptop Privacy Filter In Stock £29.07
FNLC StarTech.com 17.3" Laptop Privacy Filter In Stock £31.79
FNLC StarTech.com 14in MacBook Privacy Screen In Stock £32.46
FNLC StarTech.com 14in Laptop Privacy Screen In Stock £31.15
FNLC StarTech.com 15.6in Laptop Privacy Screen In Stock £28.33
FNLC StarTech.com 16in MacBook Privacy Screen In Stock £32.66
Colour: Transparent
