StarTech.com 15ft DVI Monitor Ext Cable
Quicklinx: 76RQWS00 Mfr#: DVIDSMF15
Extend your high-speed DVI-D connection with StarTech.com's quality DVI-D extension cables. Ideal for laptop-to-projector digital presentations or for connecting your flat-panel LCD monitor to your digital video card, these male-to-female cables allow you extend your existing digital connection by 15 feet. These Plug and Play-compatible, single-link cables provide a faster, stronger signal than standard extension cables, giving you crystal-clear digital pictures.
These cables work with any DVI-D single-link cables or devices and allow high-speed data transmission up to 4.95 Gbits/sec.
StarTech.com DVI Extension Cable - 15 ft - Single Link - Male to Female Cable - 1920x1200 - DVI-D Cable - Computer Monitor Cable - DVI Cord (DVIDSMF15) - DVI extension cable - 4.6 m
DVI extension cable - single link
Length
4.6 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
Plug and Play
P/N: CDP2DVIMM2MB, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
DVI extension cable
American Wire Gauge (AWG)
28
TMDS Links
Single link
Plated Connector
Nickel
Length
4.6 m
Connector
18+1 pin digital DVI (Single-Link) - male
18+1 pin digital DVI (Single-Link) - female
Plug and Play
