StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone
Quicklinx: 6LCKWS00 Mfr#: DVID4N1USB15
£27.73 ex VAT
£33.27 inc VAT
This 15ft four-in-one DVI/USB KVM cable integrates dual link DVI video quality with USB mouse and keyboard, 3.5mm audio out and microphone connections into a single, compact cable. The 4-in-1 KVM cable is a cost-effective and convenient solution that's suitable for use with dual link DVI supported USB KVM switches, allowing you to share a USB peripheral set between two computers configured for high definition output. The DVI/USB KVM cable provides guaranteed performance for dependable operation.
StarTech.com 1 5ft / 4m 4-in-1 USB Dual Link DVI-D KVM Switch Cable w/ Audio & Microphone (DVID4N1USB15) - keyboard / mouse / video / audio cable - 4.6 m
Keyboard / mouse / video / audio cable
Length
4.6 m
Connectors
24+1 pin digital DVI - male , 4 pin USB Type A - male , 2 x mini-phone stereo 3.5 mm - male
Connectors (Second End)
24+1 pin digital DVI - male , 4 pin USB Type B - male , 2 x mini-phone stereo 3.5 mm - male
P/N: SV231DDUSB, SV231DVIDDU, SV231DVIUAHR, SV231QDVIUA, SV231TDVIUA, SV431DDUSB, SV431DL2DU3A, SV431DVIDDU, SV431DVIUAHR, SV431TDVIUA
Length
4.6 m
Connectors
RoHS
6LCK StarTech.com 6 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone In Stock £7.13
6LCK StarTech.com 10 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone In Stock £8.87
6LCK StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £19.51
6LCK StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £27.73
6LCK StarTech.com 2 Port Quad Monitor Dual-Link DVI USB KVM Switch with Audio & Hub In Stock £370.46
6LCK StarTech.com 4 Port High Resolution USB DVI Dual Link KVM Switch with Audio In Stock £249.14
Price Range Ex VAT: 0 - 50
