StarTech.com 15cm USB to Lightning Cable White - Apple MFi Certified
Quicklinx: G3QXWS00 Mfr#: RUSBLTMM15CMW
Length: 15cm
Hurry, only 3 left in stock!
£10.87 ex VAT
£13.04 inc VAT
Durable Lightning Cable Reinforced with Aramid Fiber EMI Protection TPE Cable Jacket. This USB to Lightning cable withstands the daily demands of charging and syncing your mobile devices. Tested to endure strenuous wear and tear and winter and summer in-car use, the rugged cable is a must-have for both business and consumer applications.
Built for Daily Use
The durable Lightning cable has aramid fiber reinforcement that shelters it from the stress of frequent bends and twists. This also lets the cable flex without over-stretching, and strengthens the core of the cable.
Cable Key Features
Aramid fiber adds strength and durability to the cable
Insulated conductors reduce friction, provide more flexibility
EMI (electromagnetic interference) protection with aluminum-mylar foil with braided shielding
TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable and environmentally friendly
Flexible Strain Relief
The cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle. Plus, the improved inner molding resists cracking and reduces cable damage.
Connector Key Features
Lightning connector provides 12W for charging your iOS devices
Metal shield protects circuit board from EMI and reinforces the connection point
Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle
Comprehensive Product Testing & Expert Technical Support
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to our customers. Our local StarTech.com Technical Advisors have a broad product expertise and work directly with StarTech.com Engineers to provide support for our customers both pre and post-sales.
RUSBLTMM15CMW is an Apple MFi certified Lightning cable backed by a StarTech.com 2-year warranty.
Note: DuPont and Kevlar are trademarks or registered trademarks of E.I. du Pont de Nemours and Company.
  • Built for daily use
  • Flexible strain relief
StarTech.com 6 in(15cm) Durable White USB-A to Lightning Cable, Heavy Duty Rugged Aramid Fiber USB Type A to Lightning Charger/Sync Power Cord, Apple MFi Certified iPad/iPhone 12 Pro Max - iPhone 7/8/11/11 Pro - Lightning cable - Lightning / USB - 15 cm
Cable
Length
15 cm
White
Connector
USB - male
Connector (Second End)
Lightning - male
Sync and charge, EMI/RFI protection
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
15 cm
Plated Connector
Nickel
White
Connector
4 pin USB Type A - male
Apple Lightning - male
RoHS, WEEE, MFI
Shipping Width
14.5 cm
Shipping Depth
7.5 cm
Shipping Height
1.7 cm
Shipping Weight
30 g
Length: 15cm
