StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M
Quicklinx: 9STGWS00 Mfr#: USB3AUB15CMS
Length: 15cm
Hurry, only 3 left in stock!
£6.62 ex VAT
£7.94 inc VAT
Minimize clutter and position your USB 3.0 Micro devices near your desktop or laptop computer easily, with a thin, flexible cable. Does your regular USB 3.0 cable lift or push against your external hard drive causing it to move around on your desk? Are you forced to arrange your desk according to how your cable decides to bend and rest?
The USB3AUB15CMS features a slim USB wire construction that makes it easier to install your USB 3.0 devices and enables you to place them as needed throughout your workspace. Plus, the thin Micro USB connector molding makes this a great cable for mobile USB 3.0 devices too - it lets you plug into your device without having to take it out of its case for every charge and sync.
Organize your desk and your office to match your needs. This durable, lightweight cable is approximately half the thickness of a regular USB 3.0 cable giving you the freedom to place your devices as needed and with minimal clutter. The flexible, thin cable also reduces strain on the connection and prevents damage to the USB 3.0 port on your device.
Plus, the short 15cm cable length makes this an excellent solution for close-range connections and portable applications (e.g. connecting a portable hard drive to your laptop).
Charge your mobile device in your car or sync with your laptop.
As well as being ideal for connecting to your desktop devices, this cable provides the perfect solution for charging and syncing your USB 3.0 Micro B-equipped phones and tablets.
The short cable design is just right for people on the move, for providing simple, tidy connections and it fits nicely inside your laptop or tablet carrying case.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a thin Micro USB connector molding that plugs into your device even while it's inside a protective case.
  • Reliable connectivity
    This cable supports USB 3.0 standards for efficient data and power transmission, ensuring a consistent connection for your devices.
  • High-speed performance
    With a data transfer rate of up to 5 Gbps, this cable allows quick file transfers, enhancing productivity.
  • Compact design
    The short 15 cm length makes it easy to carry and convenient for use in tight spaces or on-the-go.
  • Durable construction
    Molded connectors and strain relief technology provide durability, preventing wear and tear over time.
  • Environmentally friendly
    Compliant with RoHS standards, this cable is manufactured with environmental considerations in mind.
StarTech.com 15cm 6in Short Slim USB 3.0 A to Micro B Cable M/M - Mobile Charge Sync USB 3.0 Micro B Cable for Smartphones and Tablets (USB3AUB15CMS) - USB cable - Micro-USB Type B to USB Type A - 15 cm
USB cable
Double shielded
Molded, strain relief, 5 Gbps data rate
Length
15 cm
Connector
10 pin Micro-USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: HB30A4AIB, HB30C4AIB, HB31C4AB, S2510BU33PW, S251BMU313, S251BMU3FP, S251BPU313, S251BRU33, S251SMU33EP, SLSODDU33B, SM2NGFFMBU33, SMS1BMU313, UNI251BMU33
USB cable
Double shielded
American Wire Gauge (AWG)
26/32
Plated Connector
Nickel
Length
15 cm
Connector
USB 3.0, RoHS
9STG StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.00
9STG StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £8.06
9STG StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.62
Length: 15cm
