StarTech.com 15cm (6in) Short Black Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad
Quicklinx: 9207WS00 Mfr#: USBLT15CMB
Colours:
Charge and Sync your Apple Lightning-equipped devices with reduced clutter. The USBLT15CMB 6in/15cm Black Lightning to USB Cable for iPhone, iPod and iPad enables close-range syncing and charging of your Lightning-enabled mobile digital devices. The cable is colored to suit black mobile devices and is short enough to minimize the clutter of excess cable, making it ideal for charging in your vehicle or for syncing to your laptop. Plus, the shorter cable design provides a portable solution that makes it perfect for carrying as a tablet or laptop accessory.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 15cm Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Startech 15cm (6in) Short Black Apple® 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable (USBLT15CMB) - Lightning cable - Lightning / USB - 15 cm
Cable
Double shielded
American Wire Gauge (AWG)
24/28/32
Cable Length
15 cm
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
P/N: ST4CU424, ST4CU424EU, ST4CU424UK, ST8CU824
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28/32
Jacket Material
PVC
Shielding Material
Cable Length
15 cm
Plated Connector
Nickel
Sync and charge
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS, MFI
9207 StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £13.56
9207 StarTech.com 2m (6ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £14.91
9207 StarTech.com 3m (10ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £18.04
