StarTech.com 15 m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M
Quicklinx: 7VXDWS00 Mfr#: HDMM15M
Length: 15m
11 In Stock
£50.20 ex VAT
£60.24 inc VAT
Create Ultra HD connections between your High Speed HDMI-equipped devices, at a distance of up to 15 meters - no signal booster required. The HDMM15M 15-meter High Speed HDMI cable features 2 gold-plated HDMI (male) connectors and durable high quality construction to provide a dependable HDMI to HDMI connection between devices such as Blu-Ray players, HDTVs, DVD Players, stereo receivers and more at a distance of up to 15-meters without the need of a signal booster.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
  • Reliable shielding
    Constructed with aluminum mylar foil and braid, the shielding ensures minimized interference and maintains consistent signal quality over long distances.
  • Durable connectors
    Featuring gold-plated 19-pin HDMI Type-A connectors, this cable offers excellent connectivity and corrosion resistance for dependable use.
  • High-speed performance
    With a 24 AWG rating, the cable supports high-speed data transfer, making it ideal for streaming high-definition content without lag.
  • Compatible design
    Designed with male connectors on both ends, this HDMI cable is compatible with a wide range of devices, providing flexibility in setup.
  • Environmentally friendly
    This product is compliant with RoHS standards, ensuring that it meets environmental regulations while delivering performance.
StarTech.com 15m High Speed HDMI Cable Ultra HD 4k x 2k HDMI Cable M/M - HDMI cable - 15 m
Cable
HDMI cable
Shielded
American Wire Gauge (AWG)
24
Length
15 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
HDMI cable
Shielded
24
Jacket Material
PVC
Shielding Material
Length
15 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
7VXD StarTech.com 1m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £6.66
7VXD StarTech.com 2m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.17
7VXD StarTech.com 3m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £11.92
7VXD StarTech.com 15 m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £50.20
7VXD StarTech.com 10m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £34.49
7VXD StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £14.74
7VXD StarTech.com 7m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £28.34
7VXD StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.69
7VXD StarTech.com 0.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £6.31
7VXD StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.78
7VXD StarTech.com 0.3m (1ft) Short High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £6.88
Length: 15m
