StarTech.com 15 ft VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 8CP0WS00 Mfr#: MXT105
Length: 4.6m
Hurry, only 1 left in stock!
£5.36 ex VAT
£6.43 inc VAT
Extend your VGA monitor connections by 15ft. This 15ft SVGA/VGA monitor extension cable lets you extend your VGA cable connection by 15ft.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 15ft Coax VGA Extension Cable (MXT105HQ).
StarTech.com 15 ft VGA Monitor Extension Cable - HD15 M/F - Supports resolutions up to 800x600 (MXT105) - VGA extension cable - 4.6 m
VGA extension cable
Length
4.6 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
Grey
P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM
VGA extension cable
Length
4.6 m
Grey
Connector
15 pin HD D-Sub (HD-15) - female
Length: 4.6m
Stock Status: In stock
