Connect USB 3.0 devices up to 5m away, with no signal loss. You don't need to be limited by a standard-sized USB cable. This active USB 3.1 Gen 1 (5 Gbps) cable, better known as a USB 3.0 cable, lets you position your USB Type-B peripherals where you need them, up to 5 meters away from your computer.
Now, you can locate USB devices such as portable hard drives and external video capture devices to make better use of your workspace. This 5-meter (15-foot) cable has a built-in equalizing chip that delivers a reliable connection, with no signal loss, beyond the 3-meter limit of standard USB 3.0 cables.
                Durable and reliable constructionThe molded design of this USB cable is crafted for resilience, ensuring it withstands typical wear and tear while maintaining a solid connection.
                High-speed data transferWith a data rate of up to 5 Gbps, this cable ensures efficient data transfer, meeting the demands of modern USB devices.
                Low signal interferenceThe double-shielded construction minimizes external interference, enabling consistent performance during data transfer without disruptions.
                Flexibility in connectivityAt 5 m in length, this cable offers the convenience of connecting devices across greater distances without sacrificing speed.
                Compatible with various devicesDesigned with a 9-pin USB Type-B connector on one end and a 9-pin USB Type-A connector on the other, this cable is versatile for various USB devices.
- StarTech.com 5m 15 ft Active USB 3.0 USB-A to USB-B Cable - M/M - USB A to B Cable - USB 3.1 Gen 1 (5 Gbps) (USB3SAB5M) - USB cable - USB Type B to USB Type A - 5 m
- USB cable
- Technology
- Double shielded
- Molded, 5 Gbps data rate
- Length
- 5 m
- Connector
- 9 pin USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- 2-year warranty
- Designed For
- P/N: ST1030USBM
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Length
- 5 m
- Black
- Connector
- USB 3.0, RoHS
- 2-year warranty
- Designed For
- P/N: ST1030USBM
|  | StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £81.57 |
|  | StarTech.com 15 ft USB 3.0 A to B Cable M/M | In Stock | £79.70 |
|  | StarTech.com 30 ft USB 3.0 A to B Cable M/M | In Stock | £102.80 |
