StarTech.com 15 ft USB 3.0 A to B Cable M/M
Quicklinx: BJWXWS00 Mfr#: USB3SAB5M
Length: 5m
13 in stock
£78.23 ex VAT
£93.87 inc VAT
Connect USB 3.0 devices up to 5m away, with no signal loss. You don't need to be limited by a standard-sized USB cable. This active USB 3.1 Gen 1 (5 Gbps) cable, better known as a USB 3.0 cable, lets you position your USB Type-B peripherals where you need them, up to 5 meters away from your computer.
Now, you can locate USB devices such as portable hard drives and external video capture devices to make better use of your workspace. This 5-meter (15-foot) cable has a built-in equalizing chip that delivers a reliable connection, with no signal loss, beyond the 3-meter limit of standard USB 3.0 cables.
StarTech.com 5m 15 ft Active USB 3.0 USB-A to USB-B Cable - M/M - USB A to B Cable - USB 3.1 Gen 1 (5 Gbps) (USB3SAB5M) - USB cable - USB Type B to USB Type A - 5 m
USB cable
Double shielded
Molded, 5 Gbps data rate
Length
5 m
Connector
9 pin USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: ST1030USBM
USB cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
5 m
Connector
USB 3.0, RoHS
P/N: ST1030USBM
BJWX StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £70.33
BJWX StarTech.com 15 ft USB 3.0 A to B Cable M/M In Stock £78.23
BJWX StarTech.com 30 ft USB 3.0 A to B Cable M/M In Stock £110.99
Length: 5m
Stock Status: In stock
