Connect USB 3.0 devices up to 5m away, with no signal loss. You don't need to be limited by a standard-sized USB cable. This active USB 3.1 Gen 1 (5 Gbps) cable, better known as a USB 3.0 cable, lets you position your USB Type-B peripherals where you need them, up to 5 meters away from your computer.
Now, you can locate USB devices such as portable hard drives and external video capture devices to make better use of your workspace. This 5-meter (15-foot) cable has a built-in equalizing chip that delivers a reliable connection, with no signal loss, beyond the 3-meter limit of standard USB 3.0 cables.
Durable and reliable construction
The molded design of this USB cable is crafted for resilience, ensuring it withstands typical wear and tear while maintaining a solid connection. -
High-speed data transfer
With a data rate of up to 5 Gbps, this cable ensures efficient data transfer, meeting the demands of modern USB devices. -
Low signal interference
The double-shielded construction minimizes external interference, enabling consistent performance during data transfer without disruptions. -
Flexibility in connectivity
At 5 m in length, this cable offers the convenience of connecting devices across greater distances without sacrificing speed. -
Compatible with various devices
Designed with a 9-pin USB Type-B connector on one end and a 9-pin USB Type-A connector on the other, this cable is versatile for various USB devices.
- StarTech.com 5m 15 ft Active USB 3.0 USB-A to USB-B Cable - M/M - USB A to B Cable - USB 3.1 Gen 1 (5 Gbps) (USB3SAB5M) - USB cable - USB Type B to USB Type A - 5 m
- USB cable
- Technology
- Double shielded
- Molded, 5 Gbps data rate
- Length
- 5 m
- Connector
- 9 pin USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- 2-year warranty
- Designed For
- P/N: ST1030USBM
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Length
- 5 m
- Black
- Connector
- USB 3.0, RoHS
- 2-year warranty
- Designed For
- P/N: ST1030USBM
StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £84.93 |
StarTech.com 15 ft USB 3.0 A to B Cable M/M | In Stock | £83.00 |
StarTech.com 30 ft USB 3.0 A to B Cable M/M | In Stock | £107.04 |
