StarTech.com 15 ft USB 2.0 A to B Cable - M/M
Customer rating: 5.0* (Write a review)
Quicklinx: 401TWS00 Mfr#: USB2HAB15
Length: 4.6m
43 in stock
£4.33 ex VAT
£5.19 inc VAT
Connect USB 2.0 peripherals to your computer. The USB2HAB15 15ft USB A-to-B cable features one USB 'A' male connector and one USB 'B' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
StarTech.com 15 ft USB 2.0 A to B Cable - M/M - USB cable - 4.6 m
USB cable
Molded
Length
4.6 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
P/N: PEXUSB400, SV231DPUA, SV231DPDDUA, PEXUSB7LP, ST7200USBM, SV431DPUA, SV231HDMIUA, SAT3510U2FGB, SAT3510U2F, SV431DDVDUA, SV231DDVDUA, SV431DD2DUA, SV231DD2DUA, SV231DPU, CBUSB22, SV431DVIDGB, ST7202USBGB, SAT3520U2RGB, ST4202USBGB, SAT3510U2VGB, SAT3510U2V, SAT3520U2, SAT5210U2EGB, SV431DVIDDU
USB cable
Molded
Length
4.6 m
Connector
USB / USB 2.0, FCC
StarTech.com 1 Port USB 2.0 & 2 Port FireWire ExpressCard Laptop Combo Adapter Card, 2 Port CardBus Laptop USB 2.0 PC Card Adapter, 2 Port ExpressCard Laptop USB 2.0 Adapter Card, 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub, 20-in-1 3.5" Bay Flash Memory Card Reader, 3 Port PCI High Speed USB 2.0 Adapter Card, 3 Port PCI Low Profile High Speed USB 2.0 Adapter Card, 3.5in Silver FireWire 400 USB to IDE External Hard Drive Enclosure, 3.5in Silver USB 2.0 One Button IDE External Hard Drive Enclosure, 3.5in Silver USB 2.0 to Dual SATA JBOD External Hard Drive Enclosure, 3.5in USB FireWire SATA External Hard Drive Enclosure, 3.5in USB to SATA External Hard Drive Enclosure w/ One Button Backup, 4 Independent Port PCI Express USB 2.0 Adapter Card, 4 Port CardBus Laptop USB 2.0 PC Card Adapter, 4 Port Dual DVI USB KVM Switch w/ Audio & USB Hub, 4 Port ExpressCard Laptop USB 2.0 Adapter Card, 4 Port USB 2.0 3 Port IEEE 1394a PCI USB Firewire Combo Adapter Card, 4 Port USB 2.0 Hub - Hub - 4 ports - Hi-Speed USB, 5 Port PCI Express USB 2.0 Adapter Card, 5.25in Silver USB to IDE External Optical Drive Enclosure, 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, 7 Port USB 2.0 Hub – Portable and Compact – Bus Powered USB 2.0 Extender – USB Multiport Expander (ST7202USB), 8 Port USB to RS232 Serial DB9 Adapter Hub, Dual Profile PCI Express to 34mm and 54mm ExpressCard Adapter Card, ST7200USB , StarTech.com InfoSafe 2.5" SATA to USB 2.0 On-The-Go Drive Enclosure, 3.5 inch USB 2.0 Network Storage HD Enclosure, 3.5" eSATA & USB 2.0 SATA Drive Enclosure, 3.5" USB 2.0 SATA Aluminum HD Enclosure, 3.5" USB 2.0 SATA Hard Drive Enclosure, 3.5" USB 2.0 to IDE/SATA Hard Drive Enclosure, 5.25" eSATA/USB 2.0 SATA Optical Drive Enclosure, USB 2.0 Dual 3.5" SATA Drive Enclosure w/RAID , StarTech.com StarView DVI/VGA USB KVM Switch with Audio
Customer reviews
Write a review for the StarTech.com 15 ft USB 2.0 A to B Cable - M/M here!
Excellent quality 15 foot cable
Reviewed by Anonymous Review Posted 07/06/2006
+ Excellent solid quality cable
Don't get confused by product description. It is really 15' (feet) long and beats any other cable (e.g. Belkin)
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Length: 4.6m
Price Range Ex VAT: 0 - 50
