StarTech.com 15 ft USB 2.0 A to B Cable - M/M
Customer rating: 5.0* (Write a review)
Quicklinx: 401TWS00 Mfr#: USB2HAB15
Connect USB 2.0 peripherals to your computer. The USB2HAB15 15ft USB A-to-B cable features one USB 'A' male connector and one USB 'B' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
StarTech.com 15 ft USB 2.0 A to B Cable - M/M - USB 2.0 Cable - Black - USB Type A (M) to USB Type B (M) (USB2HAB15) - USB cable - USB to USB Type B - 4.6 m
USB cable
Molded
Length
4.6 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
P/N: ICUSB2324I, ICUSB232D, IPUSB2HD3, IPUSB2VGA2, PM1115UW, PM1115UWEU, ST12MHDLANU, ST12MHDLANUR, SV231DPDDUA2, SV231DVIUDDM, SV231USBDDM, SV431DL2DU3A, SV431DPUA2, SV431DVIUDDM, SV431USBDDM, SV565UTPDUV, SV565UTPHDU, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2NA, USB2HDCAPS, USB3EXT6INBK
USB cable
Molded
Length
4.6 m
Connector
USB / USB 2.0, FCC
P/N: ICUSB2324, ICUSB2324I, ICUSB2328, ICUSB232D, IPUSB2HD3, IPUSB2VGA2, PCI420USB, PCI625USB2I, PCIUSB7, PEXUSB4DP, PM1115UW, PM1115UWEU, RACKCOND1701, ST12MHDLANU, ST12MHDLANUR, ST4200MINI, ST4200USBM, ST4202USB, ST4202USBGB, ST7200USBM, ST7202USB, ST7202USBGB, SV231DD2DUA, SV231DDUSB, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV231DPU, SV231DPUA, SV231DVIDDU, SV231DVIUA, SV231DVIUDDM, SV231HDMIUA, SV231QDVIUA, SV231TDVIUA, SV231USB, SV231USBDDM, SV431DD2DUA, SV431DDUSB, SV431DDVDUA, SV431DL2DU3A, SV431DPUA, SV431DPUA2, SV431DVIDDU, SV431DVIUDDM, SV431TDVIUA, SV431USB, SV431USBDDM, SV565UTPDUV, SV565UTPHDU, SV831DVIU, USB2001EXT2, USB2001EXT2NA, USB2002EXT2, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB2HDCAPS, USB3EXT6INBK, USB421, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBPLATE4
401T StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £61.41
401T StarTech.com 1 ft Panel Mount USB Cable B to B - F/M In Stock £5.68
401T StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £85.03
401T StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £20.17
401T StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M In Stock £37.87
401T StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M In Stock £33.33
Customer reviews
Write a review for the StarTech.com 15 ft USB 2.0 A to B Cable - M/M here!
Excellent quality 15 foot cable
Reviewed by Anonymous Review Posted 07/06/2006
+ Excellent solid quality cable
Don't get confused by product description. It is really 15' (feet) long and beats any other cable (e.g. Belkin)
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
