StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable
Quicklinx: 8K0FWS00 Mfr#: THINTOS15
Length: 4.6m
Select:
  • 4.5m
Hurry, only 2 left in stock!
£5.45 ex VAT
£6.54 inc VAT
The THINTOS15 15 ft Toslink Optical Digital Audio Cable provides clean, accurate sound, with no distortion or signal interference.
The thin construction of this Optical SPDIF cable is perfect for installations in tight spaces. The cable features a polished lens, which helps ensure a reliable signal and high-level digital sound quality.
This 15ft Optical Audio Cable is constructed for maximum durability, for dependable, long-lasting connections.
  • Durable construction
    The cable features a PVC jacket that provides added protection against wear and tear, ensuring long-lasting use.
  • High-quality connectors
    Gold-plated male TOSLINK connectors enhance conductivity and resist corrosion, providing a reliable connection.
  • Optical audio transmission
    Utilizing fiber optic technology, this cable delivers high-fidelity audio signals for an immersive listening experience.
  • Long cable length
    At 15 ft, this cable allows for versatile placement of your audio devices, accommodating various layouts and setups.
  • RoHS compliant
    This product meets RoHS standards, ensuring it is free from hazardous substances for safer usage.
StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable - 15ft / 15 Feet Optical Audio Cable (THINTOS15) - digital audio cable (optical) - SPDIF - 4.6 m
Cable
Digital audio cable (optical) - SPDIF
Fibre optic
Length
4.6 m
Connector
TOSLINK - male
Connector (Second End)
TOSLINK - male
P/N: BT2A, FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWTLTBAT, HD202A, PEXSOUND7CH, STNDMTV100, STNDMTV70, VGA2HDPRO2, WIFI2HDVGA
Cable Type
Interface Supported
SPDIF
Fibre optic
Jacket Material
PVC
Length
4.6 m
Plated Connector
Gold
Connector
TOSLINK - male
TOSLINK - male
RoHS
Limited warranty - lifetime
Length: 4.6m
