StarTech.com 15 ft Monitor VGA Cable - HD15 MM
Quicklinx: 6BB8WS00 Mfr#: MXT101MM15
Length: 4.6m
Select:
Hurry, only 3 left in stock!
£5.03 ex VAT
£6.03 inc VAT
Attach a PC VGA port to a switchbox. This 15-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 15ft Coax VGA Cable (MXT105MMHQ).
StarTech.com 15 ft Monitor VGA Cable - HD15 MM - VGA cable - 4.6 m
VGA cable
Shielded
Length
4.6 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
Grey
P/N: DP2VGA3, HD2VGAE2, HD2VGAMICRO, MCHD2VGAE2, MDP2VGA2, MNHD2VGAE2, USB32VGAEH3, USB32VGAPRO
VGA cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
4.6 m
Grey
Connector
RoHS
Length: 4.6m
Price Range Ex VAT: 0 - 50
