Attach a PC VGA port to a switchbox. This 15-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 15ft Coax VGA Cable (MXT105MMHQ).
- StarTech.com 15 ft Monitor VGA Cable - HD15 M/M - Supports resolutions up to 800x600 (MXT101MM15) - VGA cable - 4.6 m
- VGA cable
- Technology
- Shielded
- Length
- 4.6 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- Grey
- Limited lifetime warranty
- Designed For
- P/N: CDP2VGA, CDP2VGAFC, CDP2VGAUCPW, HDMIPLATE, MDP2VGAAMM2M, MDP2VGAAMM3M, SV231DVGAU2A, SV431DVGAU2A, USB32VGAEH3, VGAPLATE
- VGA cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 4.6 m
- Grey
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
- Designed For
