StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black
Quicklinx: 920GWS00 Mfr#: MDP2VGAMM15B
Length: 4.57m
£20.72 ex VAT
£24.86 inc VAT
Connect a Mini DisplayPort-equipped PC or Mac to a VGA monitor/projector, with a 15ft long black cable. The MDP2VGAMM15B active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector at a longer distance than a standard-length cable would support, while saving the expense of additional adapters.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 15 ft Mini DisplayPort to VGA Adapter Cable - mDP to VGA Video Converter - Mini DP to VGA Cable for Mac/PC 1920x1200 - Black (MDP2VGAMM15B) - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
Active cable (signal regeneration), Thunderbolt port compatible
1 - 4.6 m
FCC, RoHS, WEEE
90 g
Enclosure Colour
Limited warranty - 3 years
60 °C
40 - 85%
920G StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White In Stock £6.04
920G StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £17.93
920G StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £17.11
920G StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £20.32
920G StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £6.99
920G StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 In Stock £14.18
Length: 4.57m
