StarTech.com 15 ft DVI-D Single Link Monitor Extension Cable - M/F
Quicklinx: 4K0FWS00 Mfr#: DVIDSMF15
Type: DVI
Length: 4.6m
Select:
Hurry, only 2 left in stock!
£14.43 ex VAT
£17.31 inc VAT
Extend your high-speed DVI-D connection with StarTech.com's quality DVI-D extension cables. Ideal for laptop-to-projector digital presentations or for connecting your flat-panel LCD monitor to your digital video card, these male-to-female cables allow you extend your existing digital connection by 15 feet. These Plug and Play-compatible, single-link cables provide a faster, stronger signal than standard extension cables, giving you crystal-clear digital pictures.
These cables work with any DVI-D single-link cables or devices and allow high-speed data transmission up to 4.95 Gbits/sec.
StarTech.com 15 ft DVI-D Single Link Monitor Extension Cable - M/F - DVI extension cable - 4.6 m
DVI extension cable - single link
Length
4.6 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
Plug and Play
P/N: ST122DVIGB, ST124DVI, ST122DVI
DVI extension cable
American Wire Gauge (AWG)
28
TMDS Links
Single link
Plated Connector
Nickel
Length
4.6 m
Connector
18+1 pin digital DVI (Single-Link) - male
18+1 pin digital DVI (Single-Link) - female
Plug and Play
StarTech.com 2 Port DVI-I Video Splitter - Digital and Analog, 4 Port DVI-I Video Splitter - Digital and Analog
Type: DVI
Length: 4.6m
Price Range Ex VAT: 0 - 50
