StarTech.com 15 ft DVI-D Single Link Cable - M/M
Quicklinx: 3ZL2WS00 Mfr#: DVIDSMM15
Type: DVI
Length: 4.6m
Select:
£13.55 ex VAT
£16.26 inc VAT
Provides a high speed, crystal clear connection between your DVI digital devices. The DVIDSMM1515ft DVI-D Single-Link Cable provides a highly reliable, purely digital connection between and is perfect for hooking up a desktop workstation to a DVI monitor, or to plug a laptop into a projector for presentations.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable monitor cable is designed to provide a high quality digital video experience.
StarTech.com 15 ft DVI-D Single Link Cable - M/M - DVI cable - 4.6 m
DVI cable - single link
Length
4.6 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
Plug and Play
P/N: BOX4CABLE, CDP2DVIW, CDPVGDVHDBP, DKT30CDVPD, DP2DVIADAP, DVI2HDMIA, DVI2VGACON, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, PEX2PCI4, PEX2PCIE4L, PEXHDCAP2, PEXHDCAP60L2, ST121UTPDVI, ST122DVIA, ST124DVIA, SV565FXDUSA, SV565UTPDUV, USB32DVCAPRO, USB3HDCAP, USBC2DVCAPRO, VS420RDVIA, VSEDIDDVI
DVI cable
American Wire Gauge (AWG)
28
TMDS Links
Single link
Length
4.6 m
Connector
18+1 pin digital DVI (Single-Link) - male
Plug and Play
Type: DVI
Length: 4.6m
Price Range Ex VAT: 0 - 50
