StarTech.com 15 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 3ZJZWS00 Mfr#: MXT105MMHQ
This 15 ft Coax VGA Monitor Cable is designed to provide the highest VGA video quality possible. Ideally suited for high resolution VGA applications (1024x768 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables and provides superior EMI interference protection by using ferrite cores near the connector ends. This 15ft cable is a reliable solution for any high-res VGA application.
StarTech.com 15 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 4.6 m
VGA cable
Triple shielded twisted pair coaxial
Ferrite bead
Length
4.6 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
UL 2919, NEC-CMG
P/N: BOX4CABLE, BOX4HDECP2, CDP2DPVGA, CDP2HDVGA, CDP2VGASA, CDP2VGAUCPW, DK30BACDD, DKT30CVAGPD, IPUSB2VGA2, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, MDPVGDVHD4K, MOD4AVHD, MOD4AVHDBT, PEXHDCAP2, PEXHDCAP60L2, ST121HDBTSC, STDHVHDBT, SV231DVGAU2A, USB32VGCAPRO, USBC2VGCAPRO, VID2VGATV3, WIFI2HDVGA
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Ferrite bead
Length
4.6 m
Connector
UL 2919, NEC-CMG
P/N: BOX4CABLE, BOX4HDECP, BOX4HDECP2, CAB1631HD, CAB831HD, CAB831HDU, CABCONS1716I, CDP2DPVGA, CDP2HDVGA, CDP2VGASA, CDP2VGAUCPW, CPNT2VGAA, DK30BACDD, DKT30CVAGPD, DP2HDVGA, DP2VGAAMM2M, DP2VGAAMM3M, DS154, DVI2VGACON, HD2VGAMICRA, HDMI2VGA, IPUSB2VGA2, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, MCHD2VGA, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, MOD4AVHD, MOD4AVHDBT, PEXHDCAP2, PEXHDCAP60L2, RACKCONS1916, SLMPT2VGA, ST1212T, ST1214T, ST1216PRO, ST1218T, ST121EXT, ST121HDBTSC, ST121R, ST121UTP, ST121UTP232, ST121UTPEP, ST122LE, ST122LEA, ST122PRO, ST122PROA, ST122UTPA, ST122UTPAL, ST122VGA, ST122VGAU, ST122W, ST124PRO, ST124UTPEA, ST124W, ST128PRO, ST222MX, ST222MXA, ST224MX, ST424MX, STDHVHDBT, STUTPEALR, STUTPWALLA, SV231DVGAU2A, SV231USBDDM, SV431DVGAU2A, SV431USBDDM, SV565DUTPU, SV565UTP, SV565UTPU, SV565UTPUL, USB32VGAEH, USB32VGAV, USB32VGCAPRO, USB3SDOCKDD, USBC2VGCAPRO, VGA2HD2, VGA2HDPRO2, VID2VGATV, VID2VGATV2, VID2VGATV3, VS221HD2VGA, VS221VGA2HD, VS410RVGAA, VS721MULTI, WIFI2HDVGA
