Brand
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable
Quicklinx: 3ZQHWS00 Mfr#: SVECONUS15
£16.12 ex VAT
£19.34 inc VAT
The SVECONUS15 15 ft 2-in-1 Ultra Thin USB VGA KVM Cable features an ultra-thin design and is constructed of only high quality materials for durability and long-term reliability. StarTech.com's professional line of 2-in-1 USB KVM switch cables are specifically designed to work with your StarView or Server Remote Control KVM switch, integrating the necessary USB and VGA connections into a single cable - reducing tangles while maintaining excellent performance.
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable - video / USB cable - 4.57 m
Video / USB cable
Length
4.57 m
Connectors
15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male
Connectors (Second End)
P/N: CAB831HDU, CABCONS1716I, RACKCONS1908, RACKCONS1916, SV1631DUSB, SV1631DUSBGB, SV1631DUSBU, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV565DUTPU, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV565UTPUL, SV831DUSB, SV831DUSBA, SV831DUSBAU, SV831DUSBGB, SV831DUSBU, SV831DUSBUK, SV841HDIE, SV841HDIEGB
Video / USB cable
Length
4.57 m
Connectors
PC 99
P/N: CAB1631HD, CAB831HD, CAB831HDU, CABCONS1716I, RACKCONS1908, RACKCONS1916, SV1631DUSB, SV1631DUSBGB, SV1631DUSBU, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV565DUTPU, SV565UTP, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV565UTPUL, SV831DUSB, SV831DUSBA, SV831DUSBAU, SV831DUSBGB, SV831DUSBU, SV831DUSBUK, SV831HD, SV841HDIE, SV841HDIEGB
3ZQH StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £16.12
3ZQH StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £457.11
3ZQH StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft In Stock £291.88
3ZQH StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £532.60
3ZQH StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £314.29
3ZQH StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £502.21
3ZQH StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD In Stock £175.56
3ZQH StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £272.49
3ZQH StarTech.com 8 Port KVM Switch Modules In Stock £211.24
Stock Status: In stock
