StarTech.com 15 ft / 4.6 m DisplayPort Cable with Latches Multipack of 10
Quicklinx: FY28WS00 Mfr#: DISPLPORT15L10PK
Length: 4.6m
£272.43 ex VAT
£326.91 inc VAT
DisplayPort 1.2 Cable Multipack 4K@60Hz HBR2 Lifetime Warranty. This DisplayPort   cable multipack provides reliable long-distance connections between your sources and displays. The 10 pack DP cables support resolutions up to 4k x 2k (4096 x 2160) @ 60Hz for high quality video.
High Quality Performance
The male to male DisplayPort cables support DP 1.2 features, including a maximum HBR2 bandwidth of 21.6 Gbps. The DP cables also support Multi-Stream (MST) for daisy-chaining multiple monitors with optional audio support. And they are backwards compatible with DisplayPort 1.1.
Reliable Latching Connectors
The black DP cables feature latches on each connector that provide a secure connection between your devices. They have a professional grade 28 AWG construction allowing for flexible and clean quality installations.
Multipack Business Solution
The DisplayPort cable bulk pack provides a convenient solution for businesses in need of multiple cables. Providing high quality and reliable DP connections for all business needs.
Comprehensive Product Testing & Expert Technical Support
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to our customers. Our local StarTech.com Technical Advisors have a broad product expertise and work directly with StarTech.com Engineers to provide support for our customers both pre and post-sales.
DISPLPORT15L10PK is backed by StarTech.com lifetime warranty and free lifetime technical support.
  • High Quality Performance
  • Reliable?Latching Connectors
    The black DP cables feature latches on each connector that provide a secure connection between your devices.?They have a professional grade?28 AWG construction allowing for?flexible and clean quality installations.
  • Multipack Business Solution
  • Comprehensive?Product Testing?&?Expert?Technical Support
    StarTech.com?conducts thorough?compatibility and performance?testing?on?all?our products?to?ensure we are meeting or?exceeding industry standards?and providing?high-quality products to our customers. Our?local?StarTech.com?Technical?Advisors?have a broad product expertise?and?work directly with StarTech.com?Engineers to?provide support for our customers?both pre and post-sales.?? DISPLPORT15L10PK is backed by StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com DisplayPort Cable with Latches - 15 ft 10 Pack DP 1.2 Cable - DisplayPort cable - DisplayPort to DisplayPort - 4.6 m
DisplayPort cable
Packaged Quantity
10 (specifications are for single item)
4K support, HBR2 support, maximum resolution 4096x2160 at 60Hz, DisplayPort Multi-Stream Transport (MST)
Length
4.6 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 1.2
Packaged Quantity
DisplayPort cable
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
4.6 m
345 g
Connector
DisplayPort 1.2, CMG, RoHS, REACH
Shipping Width
25.2 cm
Shipping Depth
33 cm
Shipping Weight
350 g
Length: 4.6m
