Brand
StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles
Quicklinx: FB6FWS00 Mfr#: RKCONSUV15
Length: 4.6m
£49.13 ex VAT
£58.95 inc VAT
This 15 ft. (4.6 m) USB KVM Cable enables your StarTech.com Rackmount LCD console and KVM switch kit to conveniently operate your VGA and USB-equipped server.
This line of KVM cables are available in variable lengths, and are the only cables engineered for guaranteed compatibility with the StarTech.com line of RKCONS series of Rackmount Consoles and KVM switches. Supported models of Rackmount LCD Consoles are: RKCONS1701, RKCONS17HD, RKCONS1708K, RKCONS1716K, RKCONS1901, RKCONS1908K, RKCONS1916K.
This KVM cable has been specifically designed for the StarTech.com line of Rackmount KVM and Console kit. The USB and VGA KVM cord is wired with a unique schematic that enables a single connector on the KVM to interface with both VGA and USB on your server. This space-saving design dramatically reduces cable-clutter in your server rack, and ensures a tidy, professional server room.
When connected to an HD rackmount console, the 15 foot KVM cable supports HD resolutions up to 1920x1200 including 1080p, maintaining the quality of your server's video card to deliver every detail in high-definition.
To support the complexities and demands of your data center, this 15 foot (4.6 meter) KVM cable is also available as a 6 foot (1.8 meter) KVM Cable (RKCONSUV6), and a 10 foot (3 meter) KVM cable (RKCONSUV10).
  • Engineered to keep your server room tidy
    This KVM cable has been specifically designed for the StarTech.com line of Rackmount KVM and console kits. The USB and VGA KVM cord is wired with a unique schematic that enables a single connector on the KVM to interface with both VGA and USB on your server. This space-saving design dramatically reduces cable clutter in your server rack, and ensures a tidy, professional server room.
  • Crystal clear picture quality
    When connected to an HD rackmount console, the 10 foot KVM cable supports HD resolutions up to 1920x1200 including 1080p, maintaining the quality of your server's video card to deliver every detail in high definition.
StarTech.com 15 ft. (4.6 m) USB KVM Cable for StarTech.com Rackmount Consoles - VGA and USB KVM Console Cable (RKCONSUV15) - video / USB cable - 4.6 m
Video / USB cable
Maximum resolution 1920 x1080
Length
4.6 m
Connectors
14 pin mini-VGA - male
Connectors (Second End)
4 pin USB Type A - male , 15 pin HD D-Sub (HD-15) - male
P/N: RKCONS1701, RKCONS1708K, RKCONS1716K, RKCONS17HD, RKCONS1901, RKCONS1908K, RKCONS1916K
Video / USB cable
Shielding Material
Jacket Material
PVC
Plated Connector
Nickel
Length
4.6 m
3 cm
1.5 cm
430 g
Connectors
FCC, RoHS, REACH
Shipping Width
1 cm
Shipping Depth
33 cm
Shipping Height
25.5 cm
Shipping Weight
435 g
Length: 4.6m
Stock Status: In stock
