StarTech.com 15.6in Laptop Privacy Screen
Quicklinx: HSVNWS00 Mfr#: 156T6-PRIVACY-SCREEN
18 In Stock
£29.68 ex VAT
£35.61 inc VAT
The StarTech.com 15.6-inch 16:10 Touch Privacy Screen is a comprehensive solution designed to protect your information and enhance your viewing experience. With its 2-way privacy protection, it effectively shields your data from side views, making it ideal for high-traffic areas or working on sensitive tasks in public spaces. The inclusion of a blue light filter and anti-glare coating addresses the common issue of eye strain, ensuring you can work comfortably for longer periods. Additionally, the screen's 60% light transmittance ensures that your display remains bright and easy to read, without compromising on privacy. Installation is made simple with the inclusion of adhesive strips, hinge tabs, and flip hinges, offering flexibility to accommodate your setup needs. Each package comes complete with everything needed for a quick and secure setup, including a set of adhesive strips, mounting tabs, flip-over tabs, a lifting tab, a plastic sleeve, and a wiping cloth. Whether you're a professional on-the-move or a student, the StarTech.com privacy screen is an essential accessory for anyone looking to secure their data and reduce eye strain.
  • Enhanced privacy
    The 15.6-inch 16:10 Touch Privacy Screen from StarTech.com offers a 2-way privacy protection, ensuring your data remains confidential with a +/- 30° visible angle. This feature is perfect for professionals on-the-go, providing peace of mind by keeping sensitive information shielded from prying eyes.
  • Eye comfort
    Equipped with a blue light filter that reduces 51% of blue light emission and an anti-glare coating, this privacy screen not only protects your privacy but also minimizes eye strain during long working hours. The 60% light transmittance ensures your screen remains clear and easy to read, even under bright lighting.
  • Versatile installation
    This privacy screen offers multiple installation options, including adhesive strips, hinge tabs, and flip hinges, making it easy to attach and remove without leaving any residue. Whether you're at the office or on-the-go, setting up your privacy screen is hassle-free.
StarTech.com 15.6-inch 16:10 Touch Privacy Screen, Anti-Glare Blue Light Filter, Laptop Monitor Screen Protector, +/- 30 Deg. View Angle, Flip-Up - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal) - 2-way
Installation Type
Adhesive, hinge tabs, flip hinges
Package Content
Wiping cloth, 1 set of adhesive strips, plastic sleeve, 2 flip-over tabs, lifting tab, 1 set of mounting tabs
Product Material
Plastic
34.2 cm 21.8 cm
100 g
Display Screen Size Compatibility
15.6"
Anti-glare, +/- 30° visible angle, 60% light transmittance, 51% blue light reduction
Product Material
Plastic
Package Content
34.2 cm
21.8 cm
Thickness
0.5 mm
100 g
24.5 cm x 39 cm x 0.54 cm / 214 g
15.6"
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:10
Limited warranty: - 2 years
