StarTech.com 15.6in Laptop Privacy Screen
Quicklinx: HSVMWS00 Mfr#: 156LT-PRIVACY-SCREEN
20 In Stock
£29.81 ex VAT
£35.77 inc VAT
The StarTech.com 15.6-inch 16:9 Touch Privacy Screen is designed to protect sensitive information from prying eyes while ensuring a comfortable viewing experience. With its 2-way privacy protection, users can work confidently in public spaces without compromising their privacy, as the screen limits the viewing angle to +/- 30°. It also features a blue light filter that reduces 51% of harmful emissions, coupled with an anti-glare coating to minimize eye strain and reflections. This privacy screen is built for convenience and durability. It includes everything needed for a quick and secure installation, such as adhesive strips, mounting tabs, and flip-over tabs, making it compatible with most 15.6" laptops. Whether you're working in a cafe, on a plane, or at a shared workspace, the StarTech.com privacy screen keeps your information private and your eyes comfortable.
  • Enhanced privacy
    The 15.6-inch 16:9 Touch Privacy Screen offers a 2-way privacy protection, ensuring your data remains confidential with a +/- 30° visible angle, making it difficult for onlookers to view your screen from the side.
  • Eye comfort
    Equipped with a blue light filter that reduces 51% of harmful blue light emissions and features an anti-glare coating, this privacy screen helps in minimizing eye strain during long working hours.
  • Easy installation
    Comes with multiple installation options including adhesive strips, hinge tabs, and flip hinges, providing a hassle-free setup for securing the privacy screen to your laptop.
  • Durable design
    Made from high-quality plastic, this privacy screen is designed to withstand daily wear and tear, ensuring long-lasting protection for your laptop's display.
StarTech.com 15.6-inch 16:9 Touch Privacy Screen, Anti-Glare Blue Light Filter, Laptop Monitor Screen Protector, +/- 30 Deg. View Angle, Flip-Up - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal) - 2-way
Installation Type
Adhesive, hinge tabs, flip hinges
Package Content
Wiping cloth, 1 set of adhesive strips, plastic sleeve, 2 flip-over tabs, lifting tab, 1 set of mounting tabs
Product Material
Plastic
34.5 cm 19.4 cm
100 g
Display Screen Size Compatibility
15.6"
Anti-glare, +/- 30° visible angle, 60% light transmittance, 51% blue light reduction
Product Material
Plastic
Package Content
34.5 cm
19.4 cm
Thickness
0.5 mm
100 g
24.5 cm x 39 cm x 0.4 cm / 208 g
15.6"
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:9
Limited warranty: - 2 years
HSVM StarTech.com Privacy Screen Adhesive Strips In Stock £6.33
