This Laptop Privacy Screen features a universal design compatible with 15.6-inch laptop screens with a 16:9 aspect ratio display. Gold Privacy Filters have a reflective surface that instantly transitions from a clear view to a mirror effect outside of the intended viewing angle, significantly improving visual privacy when working in an office or public environment.
Prevent Visual Eavesdropping
The gold security filter is a convenient solution that features a quick shift to a mirror-like effect to protect confidential data from unwanted viewers while maintaining a clear view of 60 degrees (+/- 30 degrees from the center) for the user.
Reversible Filter
The privacy filter's removable and reversible design allows users to effortlessly switch between a glossy gold side for maximum privacy and an anti-glare matte side for environments prone to glare. The matte side provides additional screen protection with a scratch- and fingerprint-resistant coating.
Hassle-free Installation
The universal design won't interfere with top-mounted webcams, sensors, or when closing the lid. The privacy filter can be installed in two different ways. Affix the privacy shield to bezel-less displays using the transparent and residue-free adhesive strips. Alternatively, use the slide mount tabs to install the privacy screen on displays with bezels. The latter is recommended when frequent reversal or removal is required.
Blue Light Reduction
Reduce eye strain and improve visual comfort with this blue light-reducing privacy shield. It blocks 40% - 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
Enhanced privacy
The 15.6-inch 16:9 Gold Laptop Privacy Screen offers an optimal level of privacy from side views outside the +/- 30° viewing angle, ensuring your data remains confidential during mobile work or while in public spaces. -
Durable design
Crafted with a fingerprint-resistant coating and scratch-resistant material, this privacy screen is designed to withstand daily wear and tear, maintaining its clarity and effectiveness over time. -
Versatile installation
Featuring both plug-in and adhesive options, the privacy screen provides flexibility in installation according to user preference. Its removable nature allows for easy attachment and detachment without leaving residue. -
Blue light reduction
With a 51% blue light reduction, this privacy screen not only protects your privacy but also reduces eye strain, making it ideal for extended periods of use.
- StarTech.com 15.6-inch 16:9 Gold Laptop Privacy Screen, Reversible Filter w/Enhanced Privacy, Computer Security Filter, Removable Screen Protector/Shield, +/- 30 Deg. - notebook privacy filter (horizontal)
- Product Type
- Notebook privacy filter (horizontal)
- Installation Type
- Removable - plug-in/adhesive
- Package Content
- Adhesive strip, wiping cloth, mounting tabs, plastic sleeve
- Black, gold
- Product Material
- Plastic
- Display Screen Size Compatibility
- 15.6"
- Fingerprint-resistant coating, +/- 30° visible angle, 51% blue light reduction
- 2-year warranty
- Product Type
- Product Material
- Plastic
- Package Content
- Shipping Dimensions (WxDxH) / Weight
- 39 cm x 24.5 cm x 0.1 cm / 236 g
- 15.6"
- Black, gold
Display Filter
- Installation Type
- Scratch Resistant
- Mounting Kit
- Included
- Limited warranty: - 2 years
StarTech.com Privacy Screen Adhesive Strips | In Stock | £5.85 |
StarTech.com 14in Laptop Privacy Screen | In Stock | £31.15 |
