StarTech.com 15.6" Laptop Privacy Filter
Quicklinx: HDGKWS00 Mfr#: 156L-PRIVACY-SCREEN
Device Type: Laptop
Type: Privacy Screen
Device Screen Size: 15.6
Colour: Transparent
13 In Stock
£29.80 ex VAT
£35.76 inc VAT
Laptop privacy screen features a universal design compatible with 15.6" 16:9 aspect ratio displays. The anti-glare design provides visual comfort while reducing the adverse effects of blue light emitted from the screen. Reversible design allows you to quickly adjust to different light conditions throughout the day.
  • Prevent Visual Eavesdropping
    This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your computer's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
  • Reversible Filter
    The privacy screen protector is reversible, with a matte anti-glare side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint and scratch resistant coating. The privacy shield has a light transmittance of 57.5% providing optimal screen brightness and enhanced levels of privacy.
  • Hassle-free Installation
    Affix the privacy screen shield using the provided residue-free transparent adhesive strips or the side mounting tabs. The cutout on the top corner of the privacy screen makes it easy to remove for sharing content with trusted audiences or switching between the matte and glossy finishes.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort with this blue light-reducing privacy shield. It blocks up to 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 15.6-inch 16:9 Laptop Privacy Filter, Anti-Glare Privacy Screen w/51% Blue Light Reduction, Notebook Screen Protector w/ +/- 30 Degrees Viewing Angle, Matte/Glossy ( 156L-PRIVACY-SCREEN ) - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal)
Package Content
Mounting tabs, wiping cloth, sleeve, quick start guide, adhesive strips
Transparent
Product Material
Plastic
34.5 cm 19.4 cm
36 g
Display Screen Size Compatibility
15.6" wide
Anti-glare, 51% blue light reduction, +/- 30° visible angle, fingerprint-resistant coating, Hassle-free installation, reversible
Product Material
Plastic
Package Content
34.5 cm
19.4 cm
Thickness
0.4 mm
36 g
38.5 cm x 24.5 cm x 0.2 cm / 174 g
15.6" wide
Transparent
Finish
Glossy, matte
Display Filter
Aspect Ratio
16:9
Scratch Resistant
Limited warranty: - 2 years
HDGK StarTech.com Privacy Screen Adhesive Strips In Stock £6.33
Device Type: Laptop
Colour: Transparent
