StarTech.com 15.6" Laptop Backpack w/ Case
Quicklinx: GXJRWS00 Mfr#: NTBKBAG156
Device Type: Laptop
Type: Backpack
Device Screen Size: 15.6
Colour: Black
£90.73 ex VAT
£108.87 inc VAT
15.6" Laptop Backpack with Removable Accessory Organizer Case - Professional IT Tech Backpack for Work/Travel/Commute - Ergonomic Computer Bag - Durable Ballistic Nylon - Notebook/Tablet Pockets (NTBKBAG156).
  • 15.6" Laptop Backpack
    This laptop backpack is designed and built with IT Professionals & Technicians in mind. For short or long-distance commutes, this travel-friendly IT backpack can carry your 15.6" laptop and tablet with you wherever you go. Equipped with an accessories case that can be easily removed and fits all of your IT accessories, including your laptop charger, display adapters, wireless mouse, tools, measurement instruments, and more. The laptop bag and accessory case are constructed of heavy-duty ballistic nylon to keep your items secure.
  • Removable Case for IT Accessories
    The removable travel accessories pouch (10.5in x 5.25in x 3in) is stored in its own compartment and was designed to be easily accessed using the lower side pocket of the backpack to avoid searching through or displacing other items. The hook and loop dividers can be adjusted or removed to suit your needs, and the bungee grid is perfect for storing smaller IT accessories and cables. With the case removed, the main compartment can be expanded to offer more room for any other essentials required for a short or long-term trip.
  • Ergonomic and Travel Friendly
    The computer bag features breathable ergonomic padding to help relieve strain and maximize comfort. It is designed for short distance (ie. daily commuting) and long-distance travel (ie. tradeshows and customer visits). The laptop bag features adjustable shoulder straps and a handle that is easy to grip. The laptop backpack meets most airline and TSA carry-on requirements and allows you to bundle your travel bags and rolling luggage using the integrated trolley sleeve.
  • Thoughtful Design
    There are a variety of practical pockets, including a velvet-lined pocket to store sensitive items, a pocket for water bottles, and a pocket on the shoulder strap (to keep your phone, passport, or work badge easily accessible), among others. This notebook backpack is backed by a StarTech.com limited lifetime warranty, and free lifetime technical support.
StarTech.com 15.6" Laptop Backpack with Removable Accessory Organizer Case - Professional IT Tech Backpack for Work/Travel/Commute - Ergonomic Computer Bag - Durable Ballistic Nylon - Notebook/Tablet Pockets - notebook carrying backpack
Notebook carrying backpack
Product Material
1680D ballistic nylon
Notebook Compatibility
15.6"
Padded back, padded notebook compartment, TSA friendly
Carrying Strap
Shoulder carrying straps, hook and loop strap, trolley sleeve
Checkpoint Friendly
Product Material
15.6"
Notebook Compatibility Dimensions
42.5 cm x 32.4 cm x 2.3 cm
Additional Compartments
Personal accessories, bottle, sunglasses, keys, tablet, internal mesh pockets, removable compartment
Checkpoint Friendly
Carrying Strap
Closure Type
Zipper
Ventilated Back
TSA
Limited warranty: - lifetime
GXJR StarTech.com 17.3" Laptop Backpack w/ Case In Stock £107.54
GXJR StarTech.com Universal Laptop Lock, 3-in-1 In Stock £27.78
GXJR StarTech.com Universal Laptop Lock, 3-in-1 In Stock £30.35
GXJR StarTech.com 25-Pack Universal Laptop Lock In Stock £507.39
GXJR StarTech.com 25-Pack Universal Laptop Lock In Stock £600.99
GXJR StarTech.com 25-Pack Universal Laptop Lock In Stock £627.35
GXJR StarTech.com 3-in-1 Universal Laptop Lock In Stock £27.51
Device Type: Laptop
Type: Backpack
Colour: Black
