StarTech.com 15' / 4.6 m Cable Management Sleeve - Trimmable Fabric
Quicklinx: FB6KWS00 Mfr#: WKSTNCM2
More than 50 In Stock
£19.35 ex VAT
£23.22 inc VAT
This flexible and lightweight cable-management sleeve, made of polyester and nylon fabric, provides an easy and inexpensive solution for managing cable clutter. Use it to keep cables organized behind your computer monitor, while still providing access to cables when needed. The extra-long 15 ft. (4.6 m) cable sleeve is trimmable, providing flexible use in a wide range of applications.
PROFESSIONAL CABLE ORGANIZER:
Expandable sleeving protects & reduces cable clutter at your office, computer desk, server room, home office; This cable concealer is ideal for AV, power, USB cords etc
SELF-COILING:
Cable sleeve w/ coiled design allows for cables to be independently routed through or removed without being disconnected, cable protector sleeve recoils itself as cables are run through
CUSTOM LENGTH:
This 15ft (4.6m) adjustable cable management sleeve tube can be trimmed to desired length; Connect multiple sleeves together to expand & customize your cable management solution
  • Flexible design
    This cable management sleeve features a flexible design that allows it to expand from 25 mm to 38 mm, accommodating a variety of cable sizes and ensuring a snug fit.
  • Durable materials
    Constructed from a combination of polyester and nylon fabric, the cable concealer is built to withstand daily use while protecting cables from damage.
StarTech.com 15' (4.6m) Cable Management Sleeve, Flexible Coiled Cable Wrap, 1-1.5" diameter Expandable Sleeve, Polyester Cord Manager/Protector/Concealer, Black Trimmable Cable Organizer - Cable & Wire Hider (WKSTNCM2) - cable concealer
Cable concealer
Product Material
Polyester, nylon fabric
9.8 cm 3.5 cm
Length
4.6 m
265 g
Expands from 25 mm to 38 mm
Cable concealer
Product Material
9.8 cm
3.5 cm
Length
4.6 m
265 g
46 cm x 35 cm x 36 cm / 275 g
Limited warranty: - 2 years
FB6K StarTech.com Cable Management Sleeve - 2 m In Stock £10.03
