The 14U 14in deep wall mounting bracket for patch panels delivers a sturdy and dependable equipment storage option, allowing you to wall mount data/IT equipment for a more efficient and accessible operating environment. It's the perfect solution for areas where space is at a premium like SoHo (small office, home office) environment, or space limited server room because it doesn't take any floor space.
Sturdy Construction & Easy Installation
The mounting bracket features an all-steel design and is suitable for mounting patch panels, or other slim 19in equipment to a wall, and to organize cabling or equipment in your network closet, wiring closet, back office, or IDF. The sturdy steel construction is especially helpful for durability and stability. Also, because The open frame wall rack's mounting holes are positioned 16in. apart, allowing you a simple and secure wall-stud anchoring to your existing construction framework. -
Includes Hardware
M6 square cage nuts and M6 screws are included with the wall-mount bracket, additionally, M5x25 mounting screws are included to save you the hassle of sourcing separate mounting hardware. The RACK-14U-14-BRACKET is backed by a StarTech.com lifetime warranty and free lifetime technical support.
- StarTech.com 14U Wall Mount Rack, 19" Wall Mount Network Rack, 14 inch Deep (Low Profile), Wall Mounting Patch Panel Bracket for Network Switches, IT Equipment, 77lb (35kg) Capacity - Network Equipment Rack (RACK-14U-14-BRACKET) - network device mounting bracket - 14U - 19"
- Product Type
- Network device mounting bracket
- Placing / Mounting
- Wall mountable
- Package Content
- 56 x M6 cage nuts, 56 x M6 cage screws, 56 x plastic washers, 4 x M5 x 25 mm mounting screws, 4 x plastic wall anchors
- 49.8 cm x 35.6 cm x 62.9 cm
- 5 kg
- Product Material
- Steel
- Black
- Height (Rack Units)
- 14U
- Limited lifetime warranty
- Product Type
- Wall mountable
- Package Content
- Product Material
- Steel
- 14U
- 49.8 cm
- 35.6 cm
- 62.9 cm
- 5 kg
- Enclosure Colour
- Black
- Rack Size
- 19"
- Mounting Kit
- Included
- Weight Limit
- 35 kg
- Integrated cable management, 2-post, 30 cm maximum mounting depth
- Shipping Width
- 43 cm
- Shipping Depth
- 57 cm
- Shipping Height
- 70 cm
- Shipping Weight
- 13 kg
- Limited warranty - limited lifetime warranty
StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel | In Stock | £49.48 |
StarTech.com 2U Wall-Mount Bracket | In Stock | £32.50 |
