StarTech.com 14in MacBook Privacy Screen
Quicklinx: HKKCWS00 Mfr#: 142MG-PRIVACY-SCREEN
Device Type: Macbook
Type: Privacy Screen
Device Screen Size: 14
Colour: Black, Gold
£33.79 ex VAT
£40.54 inc VAT
This laptop privacy screen is compatible with the 2021 and 2023 14" MacBook Pro laptops.
Prevent Visual Eavesdropping
This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your MacBook's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
Reversible Filter
The privacy screen protector is reversible, with a matte anti-glare side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint and scratch resistant coating. The privacy shield has a light transmittance of 57.5% providing optimal screen brightness and enhanced levels of privacy.
Hassle-free Installation
The privacy filter is an exact fit design that will not interfere with top-mounted webcams, sensors, or when closing the lid. Affix the privacy screen shield using the included transparent and residue-free adhesive strips.
Blue Light Reduction
Reduce eye strain and improve visual comfort with this blue light reducing privacy shield. It blocks up to 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
  • Enhanced privacy
    The 14-inch MacBook Pro 21/23 Privacy Screen provides privacy from side views with its +/- 30° visible angle, ensuring your sensitive information remains confidential.
  • Eye comfort
    With a 51% blue light reduction feature, this privacy screen not only protects your data but also significantly reduces eye strain, suitable for extended use.
  • Durable design
    Featuring a fingerprint-resistant coating and scratch-resistant properties, the screen maintains a clear view and pristine condition, resisting everyday scratches and smudges.
StarTech.com 14-inch MacBook Pro 21/23 Privacy Screen, Gold Filter w/Enhanced Privacy, Computer Security Shield, Double-Sided Screen Protector, +/- 30 Deg. - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal)
Installation Type
Removable - adhesive
Package Content
Wiping cloth, adhesive strip
Gold, black
Product Material
Plastic
35.1 cm x 22.8 cm
90 g
Display Screen Size Compatibility
14"
51% blue light reduction, +/- 30° visible angle, fingerprint-resistant coating
Apple MacBook Pro (14.2 in, Late 2021, Late 2023)
Product Material
Plastic
Package Content
35.1 cm
22.8 cm
Thickness
0.5 mm
90 g
39 cm x 4.3 cm x 0.6 cm / 200 g
14"
Gold, black
Display Filter
Installation Type
Scratch Resistant
Mounting Kit
Included
Limited warranty: - 2 years
HKKC StarTech.com Privacy Screen Adhesive Strips In Stock £6.33
HKKC StarTech.com 16in MacBook Privacy Screen In Stock £35.04
Colour: Black
Colour: Gold
