Safeguard on-screen information - 10% brighter than standard privacy filters
This Laptop Privacy Screen is designed to work with laptops with 14-inch displays and 16:9 aspect ratio.
Prevent visual eavesdropping
This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your computer's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
Apply and Forget
Reduce eye strain and improve visual comfort by reducing blue light exposure. The 14-inch laptop screen filter is independently tested by a 3rd party lab to block 47% of blue light in the 380-450 nm range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
Flip-Over and Touch
The feature enables you to quickly flip-over the privacy filter to share contents without uninstalling the filter. Your computer touch responsiveness is preserved by the ultrathin yet robust security shield, enabling seamless use. The privacy shield has a light transmittance of up to 75% providing optimal screen brightness and enhanced levels of privacy.
Hassle-free Installation
Install the privacy screen protector using the included side mounting tabs, adhesive strips or flip-over tabs. This unit is designed for use with bezel-less or slim bezel displays.
StarTech.com Privacy Screen Adhesive Strips | In Stock | £6.33 |
StarTech.com 13.3in Laptop Privacy Screen | In Stock | £34.84 |
StarTech.com 13.3in Laptop Privacy Screen | In Stock | £34.04 |
StarTech.com 14.1in Laptop Privacy Screen | In Stock | £36.12 |
StarTech.com 15.6in Laptop Privacy Screen | In Stock | £35.98 |
StarTech.com 16in Laptop Privacy Screen | In Stock | £38.18 |
StarTech.com Lenovo X13 Yoga Gen 4 Bright Privacy Screen Filter | In Stock | £35.33 |
StarTech.com 15.6in Laptop Privacy Screen | In Stock | £36.69 |
