StarTech.com 14in Laptop Privacy Screen
Quicklinx: HSV5WS00 Mfr#: 14L61-PRIVACY-SCREEN
16 In Stock
£29.98 ex VAT
£35.97 inc VAT
The StarTech.com 14-inch 16:10 Laptop Touch Privacy Screen, Flip-Up model, is a solution designed to protect your privacy and enhance your viewing experience. This privacy screen is tailored for 14" laptops, offering a perfect fit for devices with a 16:10 aspect ratio. It features privacy protection, thanks to its Microlouver technology, which limits the viewing angle to +/- 30°, ensuring your data remains confidential even in public spaces.
Beyond privacy, the screen is engineered for comfort. It significantly reduces blue light emission by 51%, minimizing eye strain and making it more comfortable to work for extended periods. Additionally, the screen maintains 60% light transmittance, ensuring your screen remains bright and clear while safeguarding your eyes.
Installation is straightforward and adaptable, with options including adhesive strips, mounting tabs, and flip-over tabs, allowing for both permanent and temporary setups. The package comes complete with all necessary accessories, including a wiping cloth and plastic sleeve, ensuring you have everything you need for a hassle-free installation. Whether at the office, in a café, or traveling, the StarTech.com privacy screen keeps your information private and your eyes protected.
  • Enhanced privacy
    The 14-inch 16:10 Laptop Touch Privacy Screen from StarTech.com offers privacy protection, utilizing Microlouver technology to ensure that your information stays private. The screen's design limits the viewing angle to +/- 30°, effectively preventing others from seeing your screen from the side.
  • Eye comfort
    This privacy screen not only protects your information but also reduces blue light emission by 51%, and offers 60% light transmittance, making it easier on your eyes during long work sessions. The reduction in blue light helps minimize eye strain, providing a more comfortable viewing experience.
  • Versatile installation
    With multiple installation options including adhesive, hinge tabs, and flip hinges, the privacy screen offers flexibility to accommodate your working style. Whether you prefer a permanent solution with adhesive strips or a temporary setup with flip-over tabs, this screen adapts to your needs.
StarTech.com 14-inch 16:10 Laptop Touch Privacy Screen, Flip-Up - notebook privacy filter
Notebook privacy filter - 2-way
Installation Type
Adhesive, hinge tabs, flip hinges
Package Content
Wiping cloth, 1 set of adhesive strips, plastic sleeve, 2 flip-over tabs, lifting tab, 1 set of mounting tabs
Transparent
Product Material
Plastic
30.1 cm x 18.8 cm
100 g
Display Screen Size Compatibility
14"
Microlouver technology, horizontal orientation, +/- 30° visible angle, 60% light transmittance, 51% blue light reduction
Product Material
Plastic
Package Content
30.1 cm
18.8 cm
Thickness
0.5 mm
100 g
24.5 cm x 39 cm x 0.4 cm / 202 g
14"
Transparent
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:10
Mounting Kit
Included
Limited warranty: - 2 years
HSV5 StarTech.com Privacy Screen Adhesive Strips In Stock £6.19
