This laptop privacy screen features a universal design, compatible with 14" laptops with a 16:9 aspect ratio.
Prevent Visual Eavesdropping
This privacy filter is a convenient and cost-effective solution to protect your confidential data from unwanted viewers. The privacy shield darkens your laptop screen from the sides while providing a clear viewing angle of +/-30 degrees, offering a total visible area of 60 degrees.
Reversible Filter
The privacy screen protector is reversible, with an anti-glare matte side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint-resistant coating.
Hassle-free Installation
The universal design won't interfere with top-mounted webcams, sensors, or when closing the lid. The privacy screen can be installed in two different ways. Affix the privacy screen shield to bezel-less displays using the transparent and residue-free adhesive strips. Alternatively, use the slide mount tabs to install the privacy screen on displays with bezels. The latter is recommended when frequent reversal or removal is required.
Blue Light Reduction
Reduce eye strain and improve visual comfort with this blue light reducing privacy shield. It blocks 40% - 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
Enhanced privacy
The 14-inch 16:9 Laptop Privacy Screen offers an essential layer of security by limiting the viewing angle to +/- 30 degrees, ensuring your data remains confidential even in public spaces. -
Versatile installation
Featuring both plug-in and adhesive options, this privacy screen provides flexibility in installation, allowing for easy attachment and removal without leaving residue. -
Durable protection
Crafted from scratch-resistant plastic, this screen not only protects your privacy but also your screen from everyday scratches, paired with a 51% reduction in blue light for eye comfort. -
Complete accessory kit
Comes with everything needed for a hassle-free setup, including adhesive strips, mounting tabs, a plastic sleeve, and a wiping cloth, ensuring your screen remains clear and protected.
- StarTech.com 14-inch 16:9 Laptop Privacy Screen, Reversible Gold Filter w/Enhanced Privacy, Computer Security Filter, Removable Screen Protector/Shield, +/- 30 Deg. - notebook privacy filter (horizontal)
- Product Type
- Notebook privacy filter (horizontal)
- Installation Type
- Removable - plug-in/adhesive
- Package Content
- Adhesive strip, wiping cloth, mounting tabs, plastic sleeve
- Black, gold
- Product Material
- Plastic
- 31 cm x 17.4 cm
- 100 g
- Display Screen Size Compatibility
- 14"
- +/- 30° visible angle, 51% blue light reduction
- 2-year warranty
- Product Type
- Product Material
- Plastic
- Package Content
- 31 cm
- 17.4 cm
- Thickness
- 0.5 mm
- 100 g
- Shipping Dimensions (WxDxH) / Weight
- 39 cm x 24.5 cm x 0.6 cm / 222 g
- 14"
- Black, gold
Display Filter
- Installation Type
- Scratch Resistant
- Mounting Kit
- Included
- Limited warranty: - 2 years
StarTech.com Privacy Screen Adhesive Strips | In Stock | £6.19 |
StarTech.com 15.6in Laptop Privacy Screen | In Stock | £28.25 |
