This 140W USB-C GaN Charger offers a versatile, high-power charging solution for USB-C and USB-A devices, supporting up to 140W with PD 3.1. Designed for international travel, it includes interchangeable power clips for North America (NEMA 1-15P), the United Kingdom (BS 1363P), and Europe (CEE 7/16P), ensuring reliable compatibility with regional electrical standards. Engineered for optimal cooling and featuring a small foot print (3.7 in/9.6cm x 1.2in/3.08cm x 3in/7.6cm) and lightweight design (12.6 oz /358 g), this compact and portable charger delivers robust performance while maintaining a safe and efficient charging experience. It is TUV Safety Listed (IEC 62368-1), FCC/ICES EMC certified, and features Active Power Factor Correction (PF > 0.99) to enhance efficiency and prevent over-voltage, current, and temperature issues. Meeting DOE Level VI standards, it guarantees energy-efficient, reliable operation for global use.
Cool Running & Compact
This USB Wall Charger is engineered for optimal cooling, providing a safer, more reliable charging experience. Balancing compact size with powerful functionality, the power adapter features a small foot print (3.7 in/9.6cm x 1.2in/3.08cm x 3in/7.6cm) and weighs just 12.6 oz (358 g). This travel-friendly adapter combines robust capabilities with easy portability, making it an ideal companion on the go. -
Travel Ready
The power adapter includes interchangeable power clips designed to meet regional electrical standards, ensuring reliable compatibility across multiple countries. The package includes three plug types: the NEMA 1-15P for North America, the BS 1363P for the United Kingdom, and the CEE 7/16P for Europe. Each plug is engineered to maintain a secure connection and conform to its respective region's voltage and current requirements with support for 100-240V auto switching. This modular system simplifies international travel and eliminates the need for additional adapters, providing a versatile and practical solution for powering devices worldwide. A travel pouch is also included to neatly pack all the regional power clips. -
Designed for Safe Charging
Safety and efficiency are paramount with the 140W USB GaN Charger. It is TUV Safety Listed (IEC 62368-1) and FCC/ICES EMC certified, providing protection against over-voltage, current, and temperature. The Active Power Factor Correction (PF > 0.99) enhances efficiency and ensures cool operation. Additionally, it meets DOE Level VI standards, guaranteeing energy efficiency and reliable performance.
 - StarTech.com 140W USB-C Wall Charger, USB-C/USB-A, PD GaN Power Adapter power adapter - GaN technology - USB, 3 x USB-C - 140 Watt
- Product Type
 - Power adapter
- Designed For
 - Notebook
 - 7.6 cm x 9.6 cm x 3.1 cm
 - 358 g
 - Black
- Localisation
 - North America, United Kingdom, Europe
- Output Connector Type
 - Total 4: USB, 3 x USB-C
- Voltage Required
 - AC 100-240 V (50/60 Hz)
- Voltage Provided
 - 5 / 9 / 15 / 20 / 28 V
- Max Electric Current
 - 5 A
- Fast Charge Technology
 - Power Delivery 3.1
- Power Provided
 - 140 Watt
- Power Device Details
 - AC power adapter - 4 pin USB Type A - 5 V - 12 W - 2.4 A , AC power adapter - 24 pin USB-C - 28 V - 140 W - 5 A , AC power adapter: 2 x - 24 pin USB-C - 21 V - 65 W - 3.25 A
 - 2-year warranty
- Product Type
 - Power adapter
- Designed For
 - Notebook
 - 7.6 cm
 - 9.6 cm
 - 3.1 cm
 - 358 g
- Enclosure Colour
 - Black
- Localisation
- Voltage Required
- Input Connectors
 - Power NEMA 1-15
- Input Connectors Qty
 - 1
- Voltage Provided
- Output connectors
 - Total 4: 4 pin USB Type A, 3 x 24 pin USB-C
- Power Provided
 - 140 Watt
 - 5 A
 - AC power adapter: 4 pin USB Type A - 5 V - 12 W - 2.4 A , AC power adapter: 24 pin USB-C - 28 V - 140 W - 5 A , AC power adapter: 2 x 24 pin USB-C - 21 V - 65 W - 3.25 A
 - Over voltage protection, over-current protection, over-temperature protection, power factor > 0.99, Programmable Power Supply (PPS)
- Material
 - Plastic
- Included Accessories
 - 3 power plug adapters, storage pouch
 - TUV, IEC 62368-1, EMC, FCC-ICES, DoE Level VI, UL
- Shipping Width
 - 17 cm
- Shipping Depth
 - 14.2 cm
- Shipping Height
 - 3.5 cm
- Shipping Weight
 - 500 g
 - Limited warranty - 2 years
                        StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps | In Stock | £18.91 |
