This 140W USB-C GaN Charger offers a versatile, high-power charging solution for USB-C and USB-A devices, supporting up to 140W with PD 3.1. Designed for international travel, it includes interchangeable power clips for North America (NEMA 1-15P), the United Kingdom (BS 1363P), and Europe (CEE 7/16P), ensuring reliable compatibility with regional electrical standards. Engineered for optimal cooling and featuring a small foot print (3.7 in/9.6cm x 1.2in/3.08cm x 3in/7.6cm) and lightweight design (12.6 oz /358 g), this compact and portable charger delivers robust performance while maintaining a safe and efficient charging experience. It is TUV Safety Listed (IEC 62368-1), FCC/ICES EMC certified, and features Active Power Factor Correction (PF > 0.99) to enhance efficiency and prevent over-voltage, current, and temperature issues. Meeting DOE Level VI standards, it guarantees energy-efficient, reliable operation for global use.
                Cool Running & CompactThis USB Wall Charger is engineered for optimal cooling, providing a safer, more reliable charging experience. Balancing compact size with powerful functionality, the power adapter features a small foot print (3.7 in/9.6cm x 1.2in/3.08cm x 3in/7.6cm) and weighs just 12.6 oz (358 g). This travel-friendly adapter combines robust capabilities with easy portability, making it an ideal companion on the go.
                Travel ReadyThe power adapter includes interchangeable power clips designed to meet regional electrical standards, ensuring reliable compatibility across multiple countries. The package includes three plug types: the NEMA 1-15P for North America, the BS 1363P for the United Kingdom, and the CEE 7/16P for Europe. Each plug is engineered to maintain a secure connection and conform to its respective region's voltage and current requirements with support for 100-240V auto switching. This modular system simplifies international travel and eliminates the need for additional adapters, providing a versatile and practical solution for powering devices worldwide. A travel pouch is also included to neatly pack all the regional power clips.
                Designed for Safe ChargingSafety and efficiency are paramount with the 140W USB GaN Charger. It is TUV Safety Listed (IEC 62368-1) and FCC/ICES EMC certified, providing protection against over-voltage, current, and temperature. The Active Power Factor Correction (PF > 0.99) enhances efficiency and ensures cool operation. Additionally, it meets DOE Level VI standards, guaranteeing energy efficiency and reliable performance.
- StarTech.com 140W USB-C Wall Charger, USB-C/USB-A, PD GaN Power Adapter power adapter - GaN technology - USB, 3 x USB-C - 140 Watt
- Product Type
- Power adapter
- Designed For
- Notebook
- 7.6 cm x 9.6 cm x 3.1 cm
- 358 g
- Black
- Localisation
- North America, United Kingdom, Europe
- Output Connector Type
- Total 4: USB, 3 x USB-C
- Voltage Required
- AC 100-240 V (50/60 Hz)
- Voltage Provided
- 5 / 9 / 15 / 20 / 28 V
- Max Electric Current
- 5 A
- Fast Charge Technology
- Power Delivery 3.1
- Power Provided
- 140 Watt
- Power Device Details
- AC power adapter - 4 pin USB Type A - 5 V - 12 W - 2.4 A , AC power adapter - 24 pin USB-C - 28 V - 140 W - 5 A , AC power adapter: 2 x - 24 pin USB-C - 21 V - 65 W - 3.25 A
- 2-year warranty
- Product Type
- Power adapter
- Designed For
- Notebook
- 7.6 cm
- 9.6 cm
- 3.1 cm
- 358 g
- Enclosure Colour
- Black
- Localisation
- Voltage Required
- Input Connectors
- Power NEMA 1-15
- Input Connectors Qty
- 1
- Voltage Provided
- Output connectors
- Total 4: 4 pin USB Type A, 3 x 24 pin USB-C
- Power Provided
- 140 Watt
- 5 A
- AC power adapter: 4 pin USB Type A - 5 V - 12 W - 2.4 A , AC power adapter: 24 pin USB-C - 28 V - 140 W - 5 A , AC power adapter: 2 x 24 pin USB-C - 21 V - 65 W - 3.25 A
- Over voltage protection, over-current protection, over-temperature protection, power factor > 0.99, Programmable Power Supply (PPS)
- Material
- Plastic
- Included Accessories
- 3 power plug adapters, storage pouch
- TUV, IEC 62368-1, EMC, FCC-ICES, DoE Level VI, UL
- Shipping Width
- 17 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 3.5 cm
- Shipping Weight
- 500 g
- Limited warranty - 2 years
|  | StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps | In Stock | £18.91 |
