StarTech.com 14 ft Cat 6a Gray Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
Quicklinx: 7NWHWS00 Mfr#: C6ASPAT14GR
Length: 4.3m
Colour: Grey
£14.65 ex VAT
£17.58 inc VAT
Make 10Gb Ethernet connections with PoE support. This high quality 14ft Cat 6a cable (STP) ensures dependable Ethernet connectivity, supporting 10 Gigabit performance up to 500 MHz - double that of standard Category 6 cable and five times the bandwidth offered by Cat5 - an excellent choice for Power over Ethernet (PoE) applications.
Plus, Cat 6a cables are backward-compatible with Cat5e and Cat6 cables, ensuring versatile network connection options.
All of the Cat 6a cables are constructed of high quality 25 AWG shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that the Cat 6a cables are more than suitable for 10GBase-T Ethernet networks and Power over Ethernet applications.
StarTech.com 14 ft CAT6a Ethernet Cable - 10 Gigabit Category 6a Shielded Snagless RJ45 100W PoE Patch Cord - 10GbE Gray UL/TIA Certified - patch cable - 4.3 m - grey
Patch cable - CAT 6a
Shielded twisted pair (STP)
Wiring Scheme
T568B
Shielding Material
Aluminium-polyester foil
Molded
Length
4.3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Molded
Length
4.3 m
Grey
Connector
RJ-45 - male
RJ-45 - male
UL 444, RoHS - up to 500 MHz
Length: 4.3m
Colour: Grey
Price Range Ex VAT: 0 - 50
