Make 10Gb Ethernet connections with PoE support. This high quality 14ft Cat 6a cable (STP) ensures dependable Ethernet connectivity, supporting 10 Gigabit performance up to 500 MHz - double that of standard Category 6 cable and five times the bandwidth offered by Cat5 - an excellent choice for Power over Ethernet (PoE) applications.
All of Cat 6a cables are constructed of high quality 25 AWG shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that Cat6a cables are more than suitable for 10GBase-T Ethernet networks and Power over Ethernet applications.
StarTech.com Cat 6a patch cables provide end-to-end solutions that are tested for compliance with all TIA/ETL-568-B2.10 Category 6, UL 444 and ROHS 2002/95/EC specifications.
- StarTech.com 14 ft Blue Cat6a / Cat 6a Shielded Patch Cable 14ft - patch cable - 4.3 m - blue
- Patch cable - CAT 6a
- Technology
- Shielded twisted pair (STP)
- Wiring Scheme
- T568B
- Shielding Material
- Aluminium-polyester foil
- Molded
- Length
- 4.3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 26
- Molded
- Length
- 4.3 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- UL 444, RoHS - up to 500 MHz
