This Laptop Privacy Screen is designed to work with your M2 and M3 2023 13-inch MacBook Air.
Prevent visual eavesdropping
This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your computer's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user. -
Reversible Filter
The privacy screen protector is reversible, with a matte anti-glare side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint and scratch resistant coating. The privacy shield has a light transmittance of 60% providing optimal screen brightness and enhanced levels of privacy. -
Hassle-free Installation
Attach the privacy screen shield using the slim built-in magnetic strips. Included protective sleeve to stow away/protect the privacy screen from damage when not in use. -
Blue Light Reduction
Reduce eye strain and improve visual comfort by reducing blue light exposure. The 13" MacBook Air 2023 M2/M3 screen filter blocks up to 51% of the blue light emitted from the display. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
- StarTech.com 13-inch MacBook Air M2/M3 Laptop Privacy Screen, Removable and Reversible Anti-Glare Privacy Filter, Magnetic Laptop Screen Protector with +/- 30 Deg. Viewing Angle - 51% Blue Light Reduction (13MAM-PRIVACY-SCREEN) - notebook privacy filter
- Product Type
- Notebook privacy filter
- Installation Type
- Removable - magnetic
- Package Content
- Sleeve, wiping cloth
- 30 cm x 19.8 cm
- 50 g
- Display Screen Size Compatibility
- 13"
- Anti-glare, fingerprint-resistant coating, +/- 30° visible angle, 51% blue light reduction
- 2-year warranty
- Product Type
- Package Content
- 30 cm
- 19.8 cm
- Thickness
- 0.4 mm
- 50 g
- Shipping Dimensions (WxDxH) / Weight
- 39 cm x 24.5 cm x 0.4 cm / 190 g
- 13"
Display Filter
- Installation Type
- Scratch Resistant
- Mounting Kit
- Included
- Limited warranty: - 2 years
StarTech.com Privacy Screen 13.3" Laptop | In Stock | £31.72 |
StarTech.com Privacy Screen For 14" Laptop | In Stock | £32.40 |
StarTech.com Privacy Screen For 16" Laptop | In Stock | £48.28 |
