StarTech.com 13in MacBook Air Laptop Privacy Screen
Quicklinx: HM9JWS00 Mfr#: 13MAM-PRIVACY-SCREEN
Device Type: Macbook
Type: Privacy Screen
Device Screen Size: 13
Colour: Translucent black
£28.22 ex VAT
£33.86 inc VAT
This Laptop Privacy Screen is designed to work with your M2 and M3 2023 13-inch MacBook Air.
  • Prevent visual eavesdropping
    This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your computer's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
  • Reversible Filter
    The privacy screen protector is reversible, with a matte anti-glare side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint and scratch resistant coating. The privacy shield has a light transmittance of 60% providing optimal screen brightness and enhanced levels of privacy.
  • Hassle-free Installation
    Attach the privacy screen shield using the slim built-in magnetic strips. Included protective sleeve to stow away/protect the privacy screen from damage when not in use.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort by reducing blue light exposure. The 13" MacBook Air 2023 M2/M3 screen filter blocks up to 51% of the blue light emitted from the display. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 13-inch MacBook Air M2/M3 Laptop Privacy Screen, Removable and Reversible Anti-Glare Privacy Filter, Magnetic Laptop Screen Protector with +/- 30 Deg. Viewing Angle - 51% Blue Light Reduction (13MAM-PRIVACY-SCREEN) - notebook privacy filter
Notebook privacy filter
Installation Type
Removable - magnetic
Package Content
Sleeve, wiping cloth
30 cm x 19.8 cm
50 g
Display Screen Size Compatibility
13"
Anti-glare, fingerprint-resistant coating, +/- 30° visible angle, 51% blue light reduction
Package Content
30 cm
19.8 cm
Thickness
0.4 mm
50 g
39 cm x 24.5 cm x 0.4 cm / 190 g
13"
Display Filter
Installation Type
Scratch Resistant
Mounting Kit
Included
Limited warranty: - 2 years
HM9J StarTech.com Privacy Screen 13.3" Laptop In Stock £33.98
HM9J StarTech.com Privacy Screen For 14" Laptop In Stock £35.27
HM9J StarTech.com Privacy Screen For 16" Laptop In Stock £51.42
