Brand
StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio
Quicklinx: FNLBWS00 Mfr#: PRIVSCNMAC13
23 in stock
£47.33 ex VAT
£56.79 inc VAT
Laptop Privacy Filter Blue Light Reduction Matte or Glossy 2-Year Warranty. The laptop privacy screen is easy to attach and remove. Simply attach the MacBook privacy filter to your laptop with using the magnetic strips. This magnetic privacy screen is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Protect Your Privacy
The laptop privacy filter is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. Whether travelling, working in the office or sitting in a busy coffee shop, you can have a peace of mind because you know your screen is protected with the 30+/- degree privacy viewing angle.
The display privacy filter is designed to filter b blue light (390nm~480 wavelength) that can cause eye strain and can disrupt sleeping patterns.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
This PRIVSCNMAC13 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Laptop Privacy Screen for 13 inch MacBook Pro & MacBook Air, Magnetic Removable Security Filter, Blue Light Reducing Screen Protector 16:10, Matte/Glossy, +/-30 Degree Viewing - Blue Light Filter (PRIVSCNMAC13) - notebook privacy filter
Notebook privacy filter
Installation Type
Removable - magnetic
Package Content
Wiping cloth, L folder
Transparent
Product Material
Plastic
29.7 cm 19.3 cm
37 g
Display Screen Size Compatibility
13"
Anti-glare, reversible, +/- 30° visible angle, 25% blue light reduction
P/N: LTSTND2IN1
Product Material
Plastic
Package Content
29.7 cm
19.3 cm
37 g
25.9 cm x 0.3 cm x 38.4 cm / 197 g
13"
Transparent
Display Filter
Installation Type
Aspect Ratio
16:10
Scratch Resistant
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
P/N: LTSTND2IN1
FNLB StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £46.29
FNLB StarTech.com 15in Laptop Privacy Screen - Magnetic - 16:10 Aspect Ratio In Stock £51.96
Stock Status: In stock
